Where to buy headlight harness - TCCoA Forums
post #1 of 7 (permalink) Old 06-12-2016, 12:01 PM Thread Starter
KULLER94's Avatar
as the title states, where can I find a compatible aftermarket headlight harness for my 95? I searched the forums and found some people a long time ago saying to buy for competition limited, but it seems theyre no longer around. are harnesses universal? Any help is appreciated.
KULLER94 is offline
post #2 of 7 (permalink) Old 06-12-2016, 12:29 PM
I made mine - solder, 12ga wire in several colors, cut apart a couple of 9007 ceramic pigtails, and a couple of fuses; some ring terminals; and a pair of relay sockets plus two Bosch style relays.
Cost of parts was about $25 or $30.
Fuelly
RalphP is offline
post #3 of 7 (permalink) Old 06-12-2016, 12:57 PM
Made mine too for my 9005/9006 conversion. I even hacked an old bulb apart for plug and play by soldering "trigger wires" to the old filaments.
post #4 of 7 (permalink) Old 06-12-2016, 07:51 PM
What about these guys?
https://www.amazon.com/Putco-239007H.../dp/B001MA3H3E
post #5 of 7 (permalink) Old 06-18-2016, 12:31 AM
MerkCougar's Avatar
What's the consensus on which relay to go for in terms of longevity of operation? I've seen them go for 5$ all the way to 45 although that was with an in line fuse 80amp peak, nevertheless given they look so much alike what should we look for in terms of quality?
MerkCougar is offline
post #6 of 7 (permalink) Old 06-18-2016, 12:46 AM
The $5 ones. The ones at autozone are usually Bosch, they are OEM suppliers. $45 is way too much, and anything costing that much will be complete overkill for these purposes. Even having 2 inline fuses is overkill IMO, I put 1 right after the terminal on a heavy wire where it then splits to the two relays - only one relay is operating at a time for high or low, there's zero point splitting terminals unless you had hi/low operating at the same time(don't do that)
post #7 of 7 (permalink) Old 06-18-2016, 01:19 PM
If you want a good relay, you'll have to order it from Digikey or someone.
Here's paper on relays, and the various contact types.
http://www.te.com/commerce/DocumentD...=CS&DocLang=EN
