Help! Sagging door fix gone wrong. - TCCoA Forums
post #1 of 7 (permalink) Old 06-28-2016, 05:56 PM Thread Starter
Well..... After replacing pins, I decided to replace the striker bolt since the bushing was worn.
The damn sinker for the bolt inside the body fell. lol so I need to know if there is a way to acces the inside of that body panel to get that peice of metal out.
Not sure what I'm going to do to replace it if I can't get the original back. That body sheet metal is probably too thing to weld a nut to. Any ideas?
mandersen is offline
post #2 of 7 (permalink) Old 06-28-2016, 06:22 PM
Thunderstruck95's Avatar
I'm not totally familiar with that part of the car, but could you get a strong magnet, locate the nut that fell through the body steel, and use the magnet to pull the nut back into a position where you could grab it? Just an idea...
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #3 of 7 (permalink) Old 06-28-2016, 06:42 PM
You can get back there if you remove the rear speaker and speaker cover
post #4 of 7 (permalink) Old 06-28-2016, 07:40 PM
Matt is right. Looking at my gutted FX2, the best way to get to that nut is definitely to go in through the rear speaker hole. (I hope you have smaller hands)
1995 T-Bird.
post #5 of 7 (permalink) Old 06-28-2016, 11:50 PM Thread Starter
Managed to gut rear interior and the small openings were large enough to grab it. I panicked thinking I'd lose that thing and hear rattling till the end of days.
Wasn't as bad as I thought. O well, picking up news seats this week anyways. Might as well leave everything the way it is now.
Thanks for the replies.
post #6 of 7 (permalink) Old 06-28-2016, 11:57 PM
Good deal. What seats are you getting?
1995 T-Bird.
post #7 of 7 (permalink) Old 06-29-2016, 12:46 PM Thread Starter
Just some stock grey leathers to replace my worn grease/crud filled cloth. Been kicking around the idea of buying new carpet too since I've got to take the dash apart now. Most the bulbs in my gauge cluster went out the other day.
