Mark 8 hood swap - TCCoA Forums
 1Likes
  • 1 Post By Thunderstruck95
post #1 of 14 (permalink) Old 07-11-2016, 07:16 AM Thread Starter
Mark 8 hood swap
Is it possible to put a fiberglass mark 8 hood on a 97 tbird?
The front is different but can it be easily modded to work?
thatglockguy is offline
post #2 of 14 (permalink) Old 07-11-2016, 07:31 AM
KULLER94's Avatar
No, the dimensions are too far off to make it work without a large amount of effort, at which point it wouldn't be worth it.
KULLER94 is offline
post #3 of 14 (permalink) Old 07-11-2016, 07:34 AM Thread Starter
Thanks partner, just wanted to know, fiberglass hoods for tbird are almost a $1000
post #4 of 14 (permalink) Old 07-11-2016, 07:36 AM
Only way I can see to do that would be to put the entire MarkVIII nose on, but then the shape of the fenders wouldn't match with the shape of the doors, so you would have to cut apart and weld back together 2 sets of fenders to make the body lines match. So yes, it is technically possible, however by the time you do all this work, you might as well just buy a fiberglass tbird hood.
post #5 of 14 (permalink) Old 07-11-2016, 07:36 AM
KULLER94's Avatar
Fiberpartsconcepts.com has them for $589
KULLER94 is offline
post #6 of 14 (permalink) Old 07-11-2016, 07:38 AM
Thunderstruck95's Avatar
Hmm. A Mark VIII front end on a T Bird body. I may have to try that someday...
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #7 of 14 (permalink) Old 07-11-2016, 07:40 AM
So does Supercoupeperformance.
Woodman likes this.
1995 T-Bird.
post #8 of 14 (permalink) Old 07-11-2016, 07:40 AM Thread Starter
Mikey, can I put the hood on and cut and refiberglass the front of the hood to tbird configuration?
post #9 of 14 (permalink) Old 07-11-2016, 07:41 AM Thread Starter
Thanks for the info guys I will check them out
post #10 of 14 (permalink) Old 07-11-2016, 04:27 PM
dDUBb's Avatar
As long as the fender height is the same, and you have the skills to swap the front ends of the hoods ( getting the right bonding agent for the glass / composites ) - then yes, it could be possible - the hood latch is in the same position and you would need to use the Mark hinges but they will bolt up to the Bird body. I have actually been considering this since I have a spare Mark hood in my yard, but no concrete answers as of yet. Honestly I wouldnt bother much for weight savings with a fiberglass hood as I would for engine clearance. A lot of these aftermarket hoods need a bit of work to get them to fit correctly without using hood pins.
dDUBb is offline
post #11 of 14 (permalink) Old 07-11-2016, 04:43 PM
Is this a factory hood? I thought they were aluminum.
1995 T-Bird.
post #12 of 14 (permalink) Old 07-11-2016, 04:56 PM
97-98s are aluminum, 93-96 are fiberglass
post #13 of 14 (permalink) Old 07-11-2016, 09:17 PM
miller1995's Avatar
VFN has a stock style 96/97 fiberglass hood.
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #14 of 14 (permalink) Old 07-12-2016, 06:25 AM Thread Starter
re
Thanks again Matt, didn't know the 97 hoods are aluminum, I just thought all of them were fiberglass. Well, I will wait for a 93-96.
Thinking bout swapping the hood on to a 96 tbird which is in the yard too. Then I can see all the points.
