Any way to fix the door indents? - TCCoA Forums
 1Likes
  • 1 Post By RalphP
post #1 of 11 (permalink) Old 01-16-2017, 10:25 AM Thread Starter
Natesriv's Avatar
Mine just close on a hill, won't hold themselves open.
Guessing new hinges would be the way to do it...
Natesriv is offline
post #2 of 11 (permalink) Old 01-16-2017, 11:58 AM Thread Starter
Natesriv's Avatar
Saw a good post online
Thunderbird Door Hinge Repair
I'll do that later in the year when it's warmer.
Natesriv is offline
post #3 of 11 (permalink) Old 01-16-2017, 12:23 PM
I'll give a thumbs up to that.
The driver's door on Ruby Jean (our 1991 XR7) stays open MUCH better now.
Of course, if you want to be Justin Case Covered *grins* The lower hinge kit should include a Dorman 38350 ( Dorman Products - 38350 ) ; also, Dorman has a whole-door kit ( Dorman Products - 703-270 ) that has two pins, four bushings, two E-clips.
Fuelly
RalphP is online now
post #4 of 11 (permalink) Old 01-16-2017, 12:28 PM Thread Starter
Natesriv's Avatar
sounds like a plan. will have to do at Mom's house as she has a level driveway, I'm on a slope and the garage is too small for those big old doors!
Natesriv is offline
post #5 of 11 (permalink) Old 01-16-2017, 03:25 PM
T6Rocket's Avatar
You might have the record for "the most different topics posted about in one day"!
I repaired the hinges on one door of my old '95, and it took two weekends. Had to get the egged out hole filled in with welding, or it would have just gone back to drooping eventually.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #6 of 11 (permalink) Old 01-16-2017, 06:46 PM Thread Starter
Natesriv's Avatar
I've not gotten a close enough look yet. I got the car yesterday in a slight ice storm, drove it home, washed it and in the garage, where you can't open the doors fully.
Natesriv is offline
post #7 of 11 (permalink) Old 01-17-2017, 07:23 PM Thread Starter
Natesriv's Avatar
It appears my hinges are fine, the indent holders are rubber rollers in the lower hinge, they should be round and semi flexible, mine had some flat spots. Wonder if those are replaceable.
Natesriv is offline
post #8 of 11 (permalink) Old 01-17-2017, 08:41 PM
Ahem.
Factory is kind of 8 sided.
OTOH, when the bushings start to fail, it no longer lines up.
You'll have to pull the bushings ANYWAY; just do all of it.
You'll thank me for that suggestion.
Fuelly
post #9 of 11 (permalink) Old 01-17-2017, 09:19 PM
Kenz's Avatar
I don't recall seeing replacements for those.
They are in perfect shape on my Cougar, I don't believe that the doors stay open any stronger on it than on my Tbird; they are somewhat worn and out of round on the bird.
96 Cougar Sport - T45 Swapped
Kenz is offline
post #10 of 11 (permalink) Old 01-17-2017, 09:48 PM
The Dorman 38350 is the replacement.
Kenz likes this.
Fuelly
post #11 of 11 (permalink) Old 01-18-2017, 07:28 AM Thread Starter
Natesriv's Avatar
i'll pick some up. If I turn the rollers they'll stay, but they just go back to the flat spots.
Natesriv is offline
