How to remove Upper reveal molding rear window - TCCoA Forums
post #1 of 6 (permalink) Old 10-01-2017, 01:33 PM Thread Starter
1991 5.0's Avatar
Edit:
Removed all reveal moldings..
Best solution for diy refinish for reveal molding?
They're all in good shape in comparison to most out there
But I want to really make em nice.
I thought about a light textured rock guard spray or actual primer and paint and clear.
Whats a good way to coat these doing these as a back yard garage job ...if I'm not looking for a perfect repaint and want to just top coat them with something to fill in minor peeled and chipped areas to last as long as it's black in color what's good at the auto parts to use .
The only real rubber i see is a 1/4" or less lip that sits over the windows like a seal the rest is like a coated aluminum seems to be
1991 5.0 is offline
post #2 of 6 (permalink) Old 10-01-2017, 02:40 PM
I stripped the rubberized/oxidized junk off mine back in 2009 with plan sandpaper, then primed and painted them using the Duplicolor spray cans off the shelf of the auto parts store. 8 years later it still looks fantastic.
post #3 of 6 (permalink) Old 10-01-2017, 04:46 PM Thread Starter
1991 5.0's Avatar
Just finished the rear lower
I did a textured spray liner then duplicolor flexible spray paint with clear .Looks better then before .
If I get time I'll go your route if I can find a way to trip the spray loner down to the aluminum
1991 5.0 is offline
post #4 of 6 (permalink) Old 10-01-2017, 04:47 PM Thread Starter
1991 5.0's Avatar
I may even 3m vinyl wrap over them now that they are filled and coated
1991 5.0 is offline
post #5 of 6 (permalink) Old 10-01-2017, 09:14 PM
TwoHaggard's Avatar
How do these come off again?
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
post #6 of 6 (permalink) Old 10-02-2017, 09:05 AM Thread Starter
1991 5.0's Avatar
The uppers they Pull out and press back in ...
Grab your fingers or a butter knife under the edge of trim on window side on the uppers "gently" pry upward some it will unclip..all the way across the rear front and back glass.
The single lower rear glass molding slide the round tabs backwards with a flat head or tool they are located in front rubber trunk seal "don't pry up" or theyll break
There is maybe 8- 10 round locking tabs.
1991 5.0 is offline
