Tools needed for front turn signal lense removal - TCCoA Forums
post #1 of 7 (permalink) Old 11-09-2017, 10:49 AM Thread Starter
1991 5.0's Avatar
Somebody back into my front turn signal driverside l ense cracked it is this difficult to get to or just like a philips screw driver going to a junkyard later to pick up a used one wasn't sure what to bring as I have not even looked on car to see other wise..i wouldn't even ask
1991 5.0 is offline
post #2 of 7 (permalink) Old 11-09-2017, 11:40 AM
Natesriv's Avatar
Easy, from under the hood are two bolts on the inner side of each, and one alignment pin. Undo the bolts, unscrew the light plug and it'll pop right out.
I bought new ones on eBay since I doubt the junkyard will have non faded ones... who knows.
God created Arakis to train the faithful... One cannot go against the word of God.........
Natesriv is offline
post #3 of 7 (permalink) Old 11-09-2017, 06:06 PM
If memory serves, the nuts on those two studs require a 11mm wrench or socket.
post #4 of 7 (permalink) Old 11-10-2017, 09:15 AM
That's my memory also.
It may be helpful to use either an open end, ratcheting box end, or a through socket for one of them IIRC. Seems like it's rather difficult to get in there for one with a deep throat socket and a ratchet.
Also, I'd remove the headlamps first (to get room to GET to the dang nuts) IIRC.
It's been years since I've touched one, though; last time on Ruby Jean was when an Explorer tried to turn left in front of my wife and I had to repair the front end of Ruby.
Fuelly
RalphP is offline
post #5 of 7 (permalink) Old 11-10-2017, 06:51 PM
No need to pull the headlight. It really isn't difficult to get to those two nuts. R&R takes only a couple minutes.
post #6 of 7 (permalink) Old 11-10-2017, 08:54 PM
Tbird Bob's Avatar
A 7/16" wrench fits perfectly. Once loosened they are easily spun off by hand.
Tbird Bob is offline
post #7 of 7 (permalink) Old 11-11-2017, 03:16 PM
white lincoln's Avatar
I pulled both of mine last week and they are easy to get to with a 1/4" extended socket and socket wrench.
Neither of the corner lamps had the screw on the screw thread bolt. Just the two 11mm bolts.
1995 Lincoln Town Car Signature Series - 200k!
1994 Mercoury Cougar XR7 - 150k and still going.
I've had too many other cars to mention...
white lincoln is offline
