97 windshield - TCCoA Forums
 2Likes
  • 1 Post By Wile E. Coyote Jr.
  • 1 Post By XR7-4.6
post #1 of 16 (permalink) Old 03-07-2018, 03:56 AM Thread Starter
meisfatman's Avatar
97 windshield
On my 97 at the top of the windshield there's no rubber seal. It goes glass, gap, roof. I've been trying to find a replacement. On the forum however I've seen that it's built into the windshield and a should have it replaced. Can somebody please clarify this for me
meisfatman is offline
post #2 of 16 (permalink) Old 03-07-2018, 04:23 AM
The top molding is missing, sounds like someone removed it. It's a separate piece, it's not built into the windshield. Long gone obsolete too!
post #3 of 16 (permalink) Old 03-07-2018, 04:45 AM Thread Starter
meisfatman's Avatar
Is that molding or trim piece rubber or metal? Also what's the name of it?
post #4 of 16 (permalink) Old 03-07-2018, 08:09 AM
Wile E. Coyote Jr.'s Avatar
Its aluminum and is coated in rubber and is just a windshield molding, doesn't have a special name. As far as I know they arent made anymore, you have to find one online from a wrecked car or go to the junk yard. There are a few dealers that list them online but typically they dont actually have them. The coating cracks after a while so the chances of you finding a good one is slim to none, but you can paint them. I have a set of good trim I picked off a junk car but Im saving that for when mine is painted. eBay might be a good place to look.
First: Stacie, 1996 Tbird LX, mild build NPI engine, PI cams and intake, Long tube headers, Jmod.
Second: Ellie, 1989 Tbird SC, r̶e̶s̶t̶o̶r̶i̶n̶g̶ ̶t̶o̶ ̶b̶e̶ ̶n̶e̶w̶ ̶d̶a̶i̶l̶y̶. off the deep end
Third: 1997 Dodge Ram 1500, thirsty daily.
Fourth: 1990 Tbird SC, GT40 5.0 mated to m5r2, BBK long tubes, motor out the hood, drift car.
Wile E. Coyote Jr. is offline
post #5 of 16 (permalink) Old 03-07-2018, 10:51 AM
Reveal molding I do believe!
post #6 of 16 (permalink) Old 03-07-2018, 11:49 AM
Woodman's Avatar
You can use plain old rubber stripping that pretty much any windshield shop has. They did that on mine when they replaced it. It's "obsolete" for the original Ford part, but it does the job just fine.
Woodman is offline
post #7 of 16 (permalink) Old 03-07-2018, 11:50 AM
Woodman's Avatar
The 97's had no aluminum, just rubber. I pulled one from a junkyard when I noticed mine was missing, then when I had the windshield replaced, they had rolls of it.
94/95 had an aluminum one that clips in. 96/97 glue in. I know for sure 97 does at least.
Woodman is offline
post #8 of 16 (permalink) Old 03-07-2018, 12:02 PM
My car is a 96 and has the clip in aluminum ones, and the good ones I got came off of another 96.
I know that manufactures will use left over parts if they have them so maybe I ended up finding another car that got the same treatment.
Woodman likes this.
post #9 of 16 (permalink) Old 03-07-2018, 12:48 PM
The rubber one was 97 only, the aluminum one was the same 89-96
Woodman likes this.
post #10 of 16 (permalink) Old 03-07-2018, 01:52 PM
Tbird0718's Avatar
It’s called upper reveal molding and it’s basically unobtainium at this point. Like others have stated a windshield shop can probably replace it with universal stuff I went ahead and sanded mine down nice and smooth and spray painted it black. Mine was aluminum though, urs may vary.
File Type: jpeg 6CC2E83C-DB8F-430C-8535-D55E44D1E6D8_1520452342801.jpeg (923.8 KB, 16 views)
Tbird0718 is offline
post #11 of 16 (permalink) Old 03-07-2018, 02:13 PM
My winter car has black outside window moldings damaged by scrapping ice. I looked at junkyards for a long time before spotting a nice one. When I started taking it off I realized that someone had just covered it with nice black tape.
97 V8 Swap is offline
post #12 of 16 (permalink) Old 03-07-2018, 09:15 PM Thread Starter
meisfatman's Avatar
Thanks everyone I'll definitely be going to the local shops to look.
post #13 of 16 (permalink) Old 03-10-2018, 06:37 PM
1991 5.0's Avatar
Funny this is brought up they should done rubber from day 1 on all the glass
Or at least did the rear window upper lower in rubber too on the 97 .. aluminum reveals have been visual issues screwed up for years on almost all tbirds...
1991 5.0 is offline
post #14 of 16 (permalink) Old 03-10-2018, 06:47 PM
Rubber dry rots , the aluminum ones can be refinished at least.
post #15 of 16 (permalink) Old 03-10-2018, 07:07 PM
Aluminum is better here, imho.
Rubber, exposed to the sun and air hardens, shrinks, and crumbles over time.
If it's confined in a space that limits its evaporation of the plasticizers over time, it turns back into grease eventually; like belts on a turntable, lol.
If sunlight melts the Aluminum, we've been fucked for a while, lol.
Grog6 is online now
post #16 of 16 (permalink) Old 03-10-2018, 07:14 PM
Kenz's Avatar
Pretty sure the upper window trim on my 96 Tbird is a hard plastic, it has a few small chips in it.
My Cougar looks completely different and has a smooth molding that goes completely around the windshield, it looks much nicer quality. Must be one of the small differences between the two.
96 Cougar Sport - T45 Swapped
Kenz is offline
