Need decent rear glass reveal moldings or a method to refinish them - TCCoA Forums
 2Likes
  • 2 Post By Torque
post #1 of 6 (permalink) Old 05-15-2018, 05:57 PM Thread Starter
1991 5.0's Avatar
If anyone knows where I can get a set of rear upper lower reveal moldings even in decent shape let me know .. or how I can refinish mime aluminum behind the rot but the issues is I don't know how to blend in a coating so it seals against the window a small part of the original material overlaps onto the window for a seal I'm assuming if I strip and recoat I won't have that over lap part unless I run a nice bead of caulk or poly
File Type: jpg 15264249525911578675355330873867_1526424964610.jpg (2.28 MB, 29 views)
1991 5.0 is offline
post #2 of 6 (permalink) Old 05-16-2018, 04:37 PM
I'm in the same boat,my idea is cut of the rest,tape body and glass,use Window sealer and cut carefully the extra of with a hobby knife type.I wanna tape part of the blade where the blade runs against the molding.
Somebody got a better idea I'm listening,I need them done bad.
Bad-Hoschy is offline
post #3 of 6 (permalink) Old 05-17-2018, 08:03 AM
It won't be easy replicating the original rubber lip. It's doable, but it may not look perfectly OEM upon close inspection.
I suggest:
1. Remove molding and strip it clean
2. Clean the glass
3. Replace molding on car
4. Mask off vehicle body (or mask before replacing the molding, being sure not to place tape too close to window so it can be easily and completely removed)
5. Mask off glass down the distance of the OEM lip width — it'll be tricky, as you have to follow the contour with the tape, but it's doable with patience and care
6. Spray the strip down with Flex Seal or similar to the desired thickness
The above should ensure an absolutely flush/tight seal against the glass, as well as an invisible blend with the lip into the molding, since it's all one piece of new rubber.
You could do it off-vehicle by securing heavy weight craft paper roll to the underside of the molding, then mask off the craft paper/board the distance down from the molding that matches the width of the OEM lip (or trim the lip after it dries). The craft paper would follow the contour while being stiff enough not to sag — that's assuming it doesn't absorb the Flex Seal too much. You could use standard, inexpensive craft sheets, but they aren't wide enough, so you'd likely end up with a small sunken line in the new rubber coat where two sheets meet. Unfortunately, rolls aren't cheap.
I plan on doing mine on-vehicle.
If you find that spraying the molding on-vehicle builds up too thick on the molding while trying to build up the lip, you could try a combination: rubber caulk (or gasket maker) first for the lip fill, let that cure, then lay down a thinner coat of Flex Seal over the caulk lip and stripped molding.
If you just want an almost invisible blend, you could paint the molding off-vehicle, reinstall it, then mask the glass and molding and smear black rubber caulk (or gasket maker) in for the new lip and call it done. Not sure how long it'd be before the caulk started separating from the molding, but at least initially this should blend well enough that only close inspection would show the joint.
Torque is offline
post #4 of 6 (permalink) Old 05-20-2018, 04:50 PM Thread Starter
1991 5.0's Avatar
I suggest:
2. Clean the glass
Stripped and recoated reveal moldings
1991 5.0 is offline
post #5 of 6 (permalink) Old 05-21-2018, 04:21 PM
What technique and product(s) did you use?
Torque is offline
post #6 of 6 (permalink) Old 05-21-2018, 04:39 PM Thread Starter
1991 5.0's Avatar
Just simply creative method of texturized rubber liner spray . Peeled off sanded and sprayed .
Next step is a rubber gasket of some sort to adhere under the moldings so it seals flush to window .
You could literally prime paint these for a smooth result.
1991 5.0 is offline
