1995 Tbird vs. Cougar part compatibility - TCCoA Forums
post #1 of 3 (permalink) Old 01-09-2019, 04:27 PM Thread Starter
On my 1995 Tbird I am replacing my front turn signal corner lamp assemblies.
I found some OEM '95 Cougar corners and wonder if they would fit.
The the thing is -the Cougar part numbers - E9SZ-13200-A / E9SZ-13201-A
are different from the Tbird's F4SZ-13200-A / F4SZ-13201-A.
Why the difference?
Thanks for any and all help.
'95 LX 4.6L/ '99 mustang front calipers/ '96 t-bird rear calipers/Baumann transmission/BOC chip by Lonnie/ 225.55.16 Yokohama's on Borbet 5 spoke/poly IRS/ Eibach 1.5" drop/ Lincoln pumpkin with 3.55 trac-loc/ Lincoln rear upper and lower control arms/ rebuilding '94 Mark Vlll eng. for swap/ -Edit- Engine rebuild now finished by Panhandle Performance (2-16-07)/ swap on soon - but needing to get P.I. torque converter- MSD window switch for '98 IMRC'S- rebuild current Baumann Trans--etc.
Thundernerd is offline
post #2 of 3 (permalink) Old 01-09-2019, 04:38 PM
They’re the same. E9 and F4 only denote the year, SZ on both housings denote Thunderbird service parts.
post #3 of 3 (permalink) Old 01-09-2019, 04:50 PM Thread Starter
Thank you XR7-4.6 !
Your Super Moderator moniker should be changed to Super Duper Moderator.
You not only verified the compatibility, you explained the part number coding.
Good Job - I'm putting that info to use right now.
Thank you again.
