Exterior Paint Help - Trim Removal - TCCoA Forums
post #1 of 3 (permalink) Old 03-11-2019, 07:45 PM Thread Starter
MaddMartigan's Avatar
Hey all. I decided to remove the failing side trim on the car to allow me to put my numbers on. Not that it matters a lot but I have a residue that my 3M trim adhesive removal wheel doesn't seem to remove. I removed all of the rest of the adhesive but this seems to be the residue that built up around the edges from it sitting outside so long. I've attached a pic. I've tried to use acetone and Duplicolor Wax and Adhesive remover but neither really seems to do anything to it either. Thoughts?
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #2 of 3 (permalink) Old 03-11-2019, 07:58 PM
dDUBb's Avatar
You sure its residue ?? If Acetone doesn't do the trick, it might be in the paint itself. Hard to tell from the picture .. but when I removed my trim I had some pitting left behind.
dDUBb is offline
post #3 of 3 (permalink) Old 03-11-2019, 08:00 PM Thread Starter
Technically it wasn't behind the trim. It was around the edges outside the trim. It definitely could be that though.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
Similar Threads
Exterior paint issue over spray over a entirely perfect factory paint job 1991 5.0 Exterior 12 05-27-2018 03:52 PM
exterior window trim chsplayer Exterior 3 05-26-2010 03:29 PM
paint, paint, paint.... V10man Exterior 11 08-30-2007 10:15 PM
Painting Exterior Trim Nightmist_Outlaw Exterior 5 12-25-2004 04:21 PM
