Headlight Problem - TCCoA Forums
post #1 of 2 (permalink) Old 09-14-2002, 09:07 PM Thread Starter
Question Headlight Problem
[COLOR=crimson]
Ok I got strange problem with my headlights. I got a '94 Xr7. When I have the car on with daytime running lights - both lights work
high beams - both lights work
normal lights on - only passenger side works.
Should I just replace both the bulbs and see what happens?
Donnie
94XR7 is offline
post #2 of 2 (permalink) Old 09-14-2002, 09:37 PM
I remeber reading somewhere that Daytime Running lamps just run your high beams at low power.......found it....URL=http://www.tccoa.com/articles/exterior/index.html#]Here[/URL]
So I would speculate that your driver side low beam either has a wire loose (most likely in my opinion).
Or that the driver side filament is burnt out.
--Craig
Deus003 is offline
