tires??? - TCCoA Forums
post #1 of 20 (permalink) Old 09-18-2002, 07:45 PM Thread Starter
tires???
ok i have a set of wire rims (knock 0ffs)....what is a good white wall tire size to get???...i have low profiles right now but i hate the gap in between the fender and tire so im tryin to fix it...i have hydraulics now but there not installed yet cause my car hasnt been running right so i had to buy partys to fix it so now i had to put the hydraulic install a pause and now it is running right....so can some one tell me a good size tire that will look good on a set of 15" knock off wire rims there chrome....
any help will be great
THANKS
Jay
Louisville bird is offline
post #2 of 20 (permalink) Old 09-18-2002, 08:14 PM Thread Starter
come on guys i need some help here...LOL...im going to buy new tires tomorrow...
my tire size right now is 205/60/15'....my friends told me to get 205'70/15's??? whats the difference????....will that tire size get rid of my fender gap i have???....i dont want low profiles..i want white wall tires.
thanks
JAY
post #3 of 20 (permalink) Old 09-18-2002, 09:04 PM
Hey J. Going to the 70's will add about 3/4 of an inch to the sidewall height. That will close the well gap by that much. Note that this would also raise your bird by the same.
The 70 refers to 70% of the first number, which is your tire width, sidewall to sidewall. So you are going from 60% of 205mm to 70% of 205mm for the sidewall. The difference of 20mm is about 3/4 of an inch.
Okay?
soop is offline
post #4 of 20 (permalink) Old 09-18-2002, 09:07 PM Thread Starter
ok i understand....now
thanks AGAIN SOOP!...ur great help man
Jay
post #5 of 20 (permalink) Old 09-18-2002, 09:13 PM
A pleasure.
soop is offline
post #6 of 20 (permalink) Old 09-25-2002, 01:01 AM
The Band, not the Disease!
AnthraxBird's Avatar
I HOPE YOU DIDNT GET TIRES YET! 205 sucks.. to skinny =) I'd go with 235 70R 15's. I personally am going for 245 70 R 15's though.. I cant stand those skinny tires.
EDIT: the 245's WILL Change your speedometer too, so I would go with 245 65R 15's. It's like a milimeter or 2 off from the 215-70R/15's. (I think.. VERY close to it.)
AnthraxBird is offline
post #7 of 20 (permalink) Old 09-25-2002, 09:10 AM
Refrigerator Raider Hater
GreenBird's Avatar
do not use 235/70-15s! they are far too big.
245/60-15s are just right. otherwise, use 215/70-15s.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #8 of 20 (permalink) Old 09-25-2002, 11:06 AM
Juiced, like Anthraxbird says, 205s will be very skinny, unless that's the look you're going for with the hydraulics and wire wheels. The 205s will be just under a half inch narrower than stock.
However, if you are going from 215/70s to (edit)245/65s, there will be about a third of an inch increase in sidewall height and will be over an inch wider that stock. At 70 mph you would be going ~3 mph faster than what the speedo says, or 73 mph. That is about a 4% in your speedo.
soop is offline
post #9 of 20 (permalink) Old 09-25-2002, 11:47 AM
hey does anybody have....
pics of a bird with 245/60/15? i want tp put them on my bird but i want to see what they look like. or even 235/65/15. thanx
96TBird is offline
post #10 of 20 (permalink) Old 09-25-2002, 02:05 PM
Back in Black
ShadowDragon's Avatar
Re: hey does anybody have....
Ask and ye shall recieive.. 245/60r15
ShadowDragon is offline
post #11 of 20 (permalink) Old 09-25-2002, 02:31 PM
Those painted rims look awesome
did you do them yourself?
danman is offline
post #12 of 20 (permalink) Old 09-25-2002, 02:34 PM
Back in Black
Yep, used the Dupont charcoal wheel paint and then the Dupont gloss wheel paint.
post #13 of 20 (permalink) Old 09-25-2002, 02:46 PM
Re: Re: hey does anybody have....
http://www.shadoweb.net/tbird/cc/cc05s.jpg
http://www.shadoweb.net/tbird/newtires/P9100007.jpg
Just gotta say that the bird is looking very tough. Like it very much.
On the wheels thing, what was the procedure? The coating on my aluminums is looking bad and I've never painted wheels before.
soop is offline
post #14 of 20 (permalink) Old 09-25-2002, 02:55 PM
Back in Black
Re: Re: Re: hey does anybody have....
Thanks, now to hit up the race shops here in NC for my next project...
The paint is duplicolor, not dupont.. oops http://www.duplicolor.com/products/wheel.html
I took the wheels off, I know some have done it while they are on the car but I didn't want to take that chance... basically take it off and clean the begeezus out of them. I used simple green and an SOS pad. Let them dry completely and tape/paper off the tire, I also taped off the edge since A) I like a more true balance than sticky weights can provide and B) so the entire thing wasn't so dark. Once taped off just use thin coats of spray paint, waiting about an hour between coats. Then wait a couple hours and do a few thin coats of the clear, again waiting an hour between each coat.
Then let the wheels dry overnight and ditch the tape. I did the back wheels on a Friday evening and the front wheels on a Saturday evening.
post #15 of 20 (permalink) Old 09-25-2002, 02:57 PM
No sanding necessary?
soop is offline
post #16 of 20 (permalink) Old 09-25-2002, 02:59 PM
Back in Black
If you have scuff marks or something to smooth out then yes. It is not neccessary for normal coating, just has to be ultra clean.
post #17 of 20 (permalink) Old 09-25-2002, 11:46 PM
hey thanx....
thats exactly what i needed. i like the wheels too. have you checked out my site? on the bottom of my signature. tell me how u think the graphite would look on mione cause right now they are horible looking. mym dad decided he would be nice and clean the whole wheel with an sos pad and scratched the hell out of it! i need a fix until i can find some used 17x9 cobra r's for a fairly cheap price. but thanx again!
96TBird is offline
post #18 of 20 (permalink) Old 09-25-2002, 11:53 PM
Back in Black
Re: hey thanx....
I think they would look pretty cool, they make silver and white as well as the graphite and clear that I used in case you want to stick with silver.
post #19 of 20 (permalink) Old 09-26-2002, 11:49 AM
sweet i think silver...
too guess ill be maiking a walmart run soon cause the site said they sell it there. walmart hi performance automotive wheels to go along with my ram-air from home depot automotive performance!
96TBird is offline
post #20 of 20 (permalink) Old 09-26-2002, 11:58 AM
Back in Black
Re: sweet i think silver...
Lol.. I got mine at Autozone.. although silver isn't near as hard to find as charcoal is locally.
