Clearing up foggy headlights? - TCCoA Forums
post #1 of 4 (permalink) Old 09-19-2002, 04:21 PM Thread Starter
Lightbulb Clearing up foggy headlights?
Im sure this has been asked numerous times, but humor the newbie... is there an easy way to get that foggy grime off the headlights so that they look new again, or should i just buy new headlight lenses.
GENERATION (L)X is offline
post #2 of 4 (permalink) Old 09-19-2002, 04:36 PM
If you get some polish and rub alot you should be able to clear them up....but since it is the same material it will only fog up again.
--Craig
Deus003 is offline
post #3 of 4 (permalink) Old 09-19-2002, 04:48 PM
13's or Mildly Broken
Either do what Craig said (which I have done) or buy new ones. I have finally become fed up with the yellowing around the edges and am buying new ones next spring. Mine aren't that bad since I polished them, helped with night vision alot, but I want to replace them. The yellowing stands out since I've got clear corners.
-Andy "Melon"
Melon is offline
post #4 of 4 (permalink) Old 09-19-2002, 06:08 PM
JoelBender is offline
