Fix for clicking/non functional outer door handles - TCCoA Forums
post #1 of 1 (permalink) Old 09-21-2002, 02:44 PM Thread Starter
for those of you who have ever had your outer door handle "slip" across the mechanism and click and not open the door, what you need to do is take the interior panal off, and feel around for the mechanism that opens the door, and while holding it, pull the handle, and it should work fine, if this is your problem, the solution is simple, feel just above that and you'll feel a little piece of plastic that is a clip holding the mechanism in place, mine had simply snapped out of place, push it twords the outside of the door (ie straight in) and you should hear it click, now try the door. it should work fine now.
hope this helps
pdennis93 is offline
