'97 wipers, please help! - TCCoA Forums
post #1 of 3 (permalink) Old 10-26-2004, 06:33 PM Thread Starter
My wipers only work when I push the washer fluid button and then just for a few seconds.
All other functions of the switch work, low/high beam, turn signals, washer fluid pump.
Just no straight wiper function at any speed. Any thoughts? Thanks
bill_v is offline
post #2 of 3 (permalink) Old 10-27-2004, 07:14 PM
Trumpeter Extraordinaire
IronChopz's Avatar
Check fuse #17 under the dashboard...it may be on the way out. Other ideas: see the list below. I don't have access to the 1997 service manual, but here's a "Symptom/Possible Causes" list from the 1994 manual:
Symptom Chart
ELECTRICAL--WIPERS AND WASHERS
Condition(s):
Windshield Wipers Inoperative in ALL Control Switch Positions
NOTE: Check in sequence.
Possible Source(s):
-Turn signal and windshield wiper switch (13K359).
-Bent or damaged windshield wiper mounting arm and pivot shaft (17566).
-Windshield wiper motor (17508).
-Open wire or connector.
IronChopz is offline
post #3 of 3 (permalink) Old 10-28-2004, 02:27 AM
Refrigerator Raider Hater
GreenBird's Avatar
I blew my wiper fuse before and I think that the symptoms were the the same as yours, IIRC, it's a 5A fuse.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
