Rocker panel sources??? - TCCoA Forums
post #1 of 8 (permalink) Old 11-02-2004, 12:23 PM Thread Starter
Does anyone have a source for Rocker panels. I need the driver's side. My connection at the local stealership told me they can no longer get the rockers.
V8 SuperCoupe is offline
post #2 of 8 (permalink) Old 11-02-2004, 06:14 PM
toofast4u's Avatar
Send a message via Yahoo to toofast4u
I think J.C Whitney sells them but I think they end at the back of the door.
fast as fast can be you'll never get me!!
K&N panel filter,Flowmaster cat back,Cowl induction hood,Hrbacek white face flamed gauges,Spoiler,75mm Pro-M bullet maf,MSD Super Conductor plug wires,Steeda Underdrive pulleys,Clear corners,FFRP 3:73 trac lock rear,Steeda poly IRS bushings,22r plugs,180 t-stat,Apten SCT chip,Summit fuel presurre gauge,Performance auto valve body,Updated acumulators,Deep sump tranny pan,Civic intake tube,97 center console,just a start more to come!!!
Sittin in my spare room awaiting install... Jba headers,03 Mustang t/c, and flexplate,Comp Cam Valve Spings,PI Explorer Motor,New Pi Intake,Holley High Flow Fuel Rails with Braided Lines,Mark VIII Driveshaft,Crower Cams,Trick flow pleum,Art downtubes
toofast4u is offline
post #3 of 8 (permalink) Old 11-02-2004, 07:01 PM
jk69cat's Avatar
ill check if thats true on the rockers. now, i know the s/c's are dead. but the standard ones should still be available . honestly though , if your any kinda fabricator, you can make them yourself. after all your not going to see them on your car.
mn12 less!
jk69cat is offline
post #4 of 8 (permalink) Old 11-02-2004, 07:56 PM
Johnny Bling Bling
93 lx's Avatar
they are still available. when i checked at work the other day, they have been replaced to a newer number.
2009 Ford Flex Limited AWD
93 lx is offline
post #5 of 8 (permalink) Old 11-03-2004, 01:56 PM Thread Starter
Whats the difference between the LX and SC panels?
Does anyone have a part number? Does anyone now if these are full length running from fender to fender?
Thank guys this is much appreciated as my car is at a standstill til I can get one.
post #6 of 8 (permalink) Old 11-03-2004, 02:20 PM
jk69cat's Avatar
rh f7sz6310120ab msrp is 144.13
lh f7sz6310121ab msrp is 146.70
mn12 less!
jk69cat is offline
post #7 of 8 (permalink) Old 11-03-2004, 06:26 PM Thread Starter
Thanks dude!
Your a lifesaver!
post #8 of 8 (permalink) Old 11-03-2004, 11:46 PM
jk69cat's Avatar
no problem. the only thing is those are for an lx. and you will just have to drill the mount holes for the s/c trim . and yes those run from behind the front fender to behind the rear quarter.
mn12 less!
jk69cat is offline
