adjusting headlamps - TCCoA Forums
post #1 of 3 (permalink) Old 11-06-2004, 01:34 AM Thread Starter
adjusting headlamps
How do I raise up the headlights so they point farther down the road? I had the front end replaced after an accident & now the headlights are too low. I know that there are two adjusting screws per headlamp, but not sure which screw to turn or which way to turn it.
W.Cup is offline
post #2 of 3 (permalink) Old 11-06-2004, 09:00 PM
Trumpeter Extraordinaire
IronChopz's Avatar
The screw on the outside of the assembly will adjust the assembly left-right, whereas the screw at the bottom will adjust up-down. The adjusting screws take a very small socket (~4.5mm, if I recall correctly). Turning the adjusting screws to the RH side of the vehicle should raise the aim of the headlights.
IronChopz is offline
post #3 of 3 (permalink) Old 11-08-2004, 09:37 PM
Jestkdn's Avatar
Send a message via AIM to Jestkdn Send a message via Yahoo to Jestkdn
The top knobs control the left to right, bottom one controls top to bottom. They take a 5/32 socket, I found a 5/32 wrench at Sears for $14.00 with 7 other wrenches. Only place i could find them.
I am as mechanically inclined as Hellen Keller is with a Rubik's Cube!
Jestkdn is offline
