Headlights yellowing - TCCoA Forums
post #1 of 22 (permalink) Old 11-09-2004, 07:46 PM Thread Starter
Primalzer1995's Avatar
Send a message via AIM to Primalzer1995
I am wondering what there is to do to my yellowing headlights. I've heard from TV shows like Trucks and Horse Power that bleaching works well. I don't want to spend $100 apiece to make them look nice. Any other ideas, or anyone else had any luck with other methods?
-Jon
"one word, thunder-cougar-falcon-bird!"
Primalzer1995 is offline
post #2 of 22 (permalink) Old 11-09-2004, 08:28 PM
check out big_mike
Kodiak Chick is offline
post #3 of 22 (permalink) Old 11-09-2004, 08:31 PM
$.25 poster
AlpineBird's Avatar
Send a message via AIM to AlpineBird
or check ebay...i got a new set for $150
'96 Alpine Bird 281ci
- Clear Corners
- DynoMax Cat-Back
- Purchased with 36,000 miles, now at 101k
- No mods planned untill it's DD life is over
1998 5.9 Limited Grand Cherokee
- Flowmaster Exhaust
- AEM Brute Force Intake
- Mopar Performance ECU
- 275hp-395ft/lbs at the crank (est.) Track results in the spring!!!
AlpineBird is offline
post #4 of 22 (permalink) Old 11-09-2004, 08:46 PM
big-mike is cheaper than that I believe
post #5 of 22 (permalink) Old 11-09-2004, 08:54 PM
392Bird's Avatar
I used wet/dry sand paper, 600 then 800, then Comet Soft Scrub, then a mild rubbing compound, then polish. It took about 45 mins on each one.
I bought the car new, and these are the originals. This was taken last weekend.
After cleaning, they need touched up with polish every 2 months or so.
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #6 of 22 (permalink) Old 11-09-2004, 09:28 PM Thread Starter
Did you do it inside and outside? Cause yeah definitly 150 for a pair is even too much, cleaning would be nice.
post #7 of 22 (permalink) Old 11-09-2004, 09:41 PM
392Bird's Avatar
I did the outside only. They look as clear as water now. The only thing that shows, is the thin line of discolored glue holding the lens togeter on the upper edge.
392Bird is offline
post #8 of 22 (permalink) Old 11-09-2004, 09:51 PM Thread Starter
Well i have one lense that is clear and one that is yellow (long accident story) But i also have the corner lenses, and one of those is yellowing and the other is nice and neat. Can the corners be safely done?
post #9 of 22 (permalink) Old 11-10-2004, 01:07 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
i make headlights look brand new. that includes getting rid of that pesky yellowed glue around the edges.
392 - that hood is
2014 GT
1990 300ZX TT
big mike is offline
post #10 of 22 (permalink) Old 11-10-2004, 01:24 AM Thread Starter
How might you get the pesky stuff around the edges?
post #11 of 22 (permalink) Old 11-10-2004, 07:56 AM
Good question, how do you get rid of the dis-colored glue? I just painted black around the edges.
RAYBROADWAY is offline
post #12 of 22 (permalink) Old 11-10-2004, 05:02 PM
Motorboatin' SOB
big mike's Avatar
i take the headlights apart and pull out the old glue.
2014 GT
1990 300ZX TT
big mike is offline
post #13 of 22 (permalink) Old 11-11-2004, 10:56 AM
Pawn Shop Pro
antz_tbird's Avatar
Send a message via Yahoo to antz_tbird
I was going to ask Big Mike to do some for me but I just figured ahhh the hell with it i'll just get some new ones and if those ones ever yellow then maybe big mike will help me out...
1999 Dodge Ram 1500
K&N Intake Kit
Magnaflow exhaust
-Anthony-
1995 Ford Thunderbird LX....Gone.
antz_tbird is offline
post #14 of 22 (permalink) Old 11-11-2004, 11:51 AM
Motorboatin' SOB
big mike's Avatar
a new pair costs more than what i charge. its up to you though
2014 GT
1990 300ZX TT
big mike is offline
post #15 of 22 (permalink) Old 11-29-2004, 06:41 PM
they make a little cleaning kit that has a base,oxidation,final and after i put my clear corners on i needed to change the yellow fronts...worked great! dont even have to remove anything, can get the brand name for someone if they wanna go try it.
chromecoupe is offline
post #16 of 22 (permalink) Old 11-30-2004, 11:30 AM
How do you get the head lights apart, I have 2 sets that are horrid and 1 set I need to do on the inside.
sc0tty8 is offline
post #17 of 22 (permalink) Old 11-30-2004, 02:31 PM
Motorboatin' SOB
big mike's Avatar
i use two thin flatblade screwdrivers to pry the lens and housing apart.
2014 GT
1990 300ZX TT
big mike is offline
post #18 of 22 (permalink) Old 12-01-2004, 12:15 AM
Banned
before and after pics of mikes cleaning service...thanx again
before
after
yummmm
Porkchop is offline
post #19 of 22 (permalink) Old 12-09-2004, 03:54 PM
ben_cline's Avatar
Getting them done by mike is the better way, unless you can do it yourself, but he's a pro at it by now. As for something you can do to make them look better for the time-being is to use some clear plastic cleaner/polish from Meguiar's.
You can see the one is still cloudy compared to the clear corner, but it's better than the other one.
ben_cline is offline
post #20 of 22 (permalink) Old 12-09-2004, 10:49 PM
Banned
its as clean as its gonna get...my suggestion...jus paint over the part like shadow did or you can take the lens apart *not THAT hard* and clean off all the old factory glue and re-seal it with clear silicone glue...works wonders jus takin off the glue..cuz you can see that the lenses are clear but remain yellow in some areas...just replace the factory glue adn you'll be fine
Porkchop is offline
post #21 of 22 (permalink) Old 12-10-2004, 01:23 AM
Rob
Rob's Avatar
Send a message via AIM to Rob
Ummm. DIZZAMM!! THose are some clean *** lenses, porkchop.
-Rob
-Rob
Rob is offline
post #22 of 22 (permalink) Old 12-10-2004, 01:25 AM
Banned
thanx to mike
>=) mwuahhahahah
Porkchop is offline
