Best Paint In The World!!! - TCCoA Forums
post #1 of 7 (permalink) Old 11-12-2004, 02:02 PM Thread Starter
joshbea6's Avatar
Exclamation Best Paint In The World!!!
For those of you who don't know, I'm in the middle of doing a COMPLETE frame-up restoration.
The frame repair shop introduced me to a paint that all of you that live in states where they use SALT on the roads will find INVALUABLE!
It is called POR-15. It is a paint that was designed primarily for the marine industry. It is used primarily for priming and sealing ship hulls.
I got to see the product demonstration at the frame shop when the paint rep was there. They painted 2 pieces of metal. One they let air dry, and the other they sunk into a 5 Gal. bucket of water. The piece that was sunk in water dried and cured FASTER than the one left to air dry.
It is some AMAZING stuff. This stuff is THICK too. The frame shop uses this stuff as a frame sealer and undercoating. Once it dries, you either have to get the car dipped to remove it, sand blast it, or grind it to get it off. They can only get about 3 uses out of a paint spray gun when using this stuff as it cures so damn hard!
Just an FYI for those of you who want to preserve their car like I do.
joshbea6 is offline
post #2 of 7 (permalink) Old 11-12-2004, 02:04 PM
Who is John Galt?
My uncle told me about that stuff when he re-did his older vette (c3 i think). he loved it.
"Won't work, can't be done"
cougar_guy04 is offline
post #3 of 7 (permalink) Old 11-12-2004, 02:17 PM
8ate8's Avatar
Send a message via AIM to 8ate8
sounds like the rhino liner stuff
Jersey Rice
NJ Thunderbird & Cougar Club
Sold '96 Thunderbird LX 3.8l :: Cardomain Page
'93 Thunderbird SC 3.8l - 12 second car. 14 second driver.
'05 Toyota X-Runner
8ate8 is offline
post #4 of 7 (permalink) Old 11-12-2004, 02:31 PM Thread Starter
joshbea6's Avatar
it's very similar to the Rhino lining, but this doesn't have the harsh rough surfacing to it.
joshbea6 is offline
post #5 of 7 (permalink) Old 11-12-2004, 04:28 PM
jk69cat's Avatar
if the cars not preped right the stuff peals
mn12 less!
jk69cat is offline
post #6 of 7 (permalink) Old 11-12-2004, 05:55 PM Thread Starter
joshbea6's Avatar
well the car has to be cleaned of all oils, etc, and rust has to be minimum, but it is a rust inhibitor and a sealant.
joshbea6 is offline
post #7 of 7 (permalink) Old 11-12-2004, 06:59 PM
That applies to any coating on any surface....
POR-15 has been used by old car restorers for a loooong time. Rust Bullet is another one that does essentially the same thing, different pros and cons for each.
doodaa is offline
