difficulty of repair? - TCCoA Forums
post #1 of 15 (permalink) Old 11-17-2004, 03:34 PM Thread Starter
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
i ran into a telephone pole on wet roads after losing control at about 20 mph (while sober). is the bumper still good other than the paint? can it be bent back into shape? the header panel and black plastic waffle thing behind the bumper are damaged. the washer fluid bottle was shoved back too. what else could be damaged?
2014 GT
1990 300ZX TT
big mike is offline
post #2 of 15 (permalink) Old 11-17-2004, 03:38 PM
Banned
hahahah while sober...yea sure...heheh you probably get high or something...
j/k
about the car im glad your ok and it looks like to me the header panel is crooked...maybe some radiator support or whatever...shouldnt be too hard to do...you ARE big mike so you'll be alright
PS...DAM your headlights are FRIGGIN CLEAN!!!
Porkchop is offline
post #3 of 15 (permalink) Old 11-17-2004, 03:41 PM
time for a 96-7 front end swap!
weswing04 is offline
post #4 of 15 (permalink) Old 11-17-2004, 03:43 PM
Banned
thats what i told him that night!!
DUUUDE!!...come on and and and you know how to take the headlights apart and you could paint the inside of them black.,..man that looks sweet
Porkchop is offline
post #5 of 15 (permalink) Old 11-17-2004, 03:48 PM Thread Starter
Motorboatin' SOB
big mike's Avatar
well i would rather do a 94-5 swap, and theres a gold 94 not too far from me thats being parted out, so i may jump on that. but if that doesnt work out, i want to know if my bumper is still good, as well as anything else that could be damaged.
2014 GT
1990 300ZX TT
big mike is offline
post #6 of 15 (permalink) Old 11-17-2004, 04:29 PM
jk69cat's Avatar
from the looks of it mike , the cover looks ok. your not goign to know what all is tweaked until you remove everything. is the bumper ripped or anything? the bracket that is rivited to the cover looks like its off. those are cheap and and easy fix.
mn12 less!
jk69cat is offline
post #7 of 15 (permalink) Old 11-17-2004, 05:53 PM Thread Starter
Motorboatin' SOB
big mike's Avatar
well i just got back from getting an estimate, which is way too much. ill end up fixing it myself most likely. upon further inspection, the two frame bumper mounts (located behind and under the headlights) are bent. the guy said i could pull that part off along with the rebar and have it bent back into place on a machine.
the bumper isnt ripped up, just bent up on the sides. the guy said it is reuseable.
2014 GT
1990 300ZX TT
big mike is offline
post #8 of 15 (permalink) Old 11-17-2004, 07:01 PM
judging by the hoodgaps, the two main front rails have swayed right and will need to get up on a frame rack to pull and measure. Please make sure to find and fix any folded metal in the structure. if you leave it, it'll fold like tin foil the next time it gets hit. go for the conversion!!
97 Mark VIII LSC yeah
08 Ford Edge, white for now
modbird is offline
post #9 of 15 (permalink) Old 11-18-2004, 01:07 AM
jk69cat's Avatar
i agree, take the nose parts off take it to a b/s and have it machine measured and pulled . it doesnt look like it need any paint work besides the front cover
mn12 less!
jk69cat is offline
post #10 of 15 (permalink) Old 11-18-2004, 02:21 AM Thread Starter
Motorboatin' SOB
big mike's Avatar
are the frame rails and metal bumper part all one big piece?
i read that it is tack welded on, so after i get it fixed, does it have to be welded back on, or is there another way i could reattach it?
2014 GT
1990 300ZX TT
big mike is offline
post #11 of 15 (permalink) Old 11-18-2004, 03:11 AM
Full Metal
RedThunder94's Avatar
nope, it's hosed, looks like you will be doing that front end swap, i'll take the bumper cover of your hands, maybe headlights, too, because you'll have the newer style lights, i'll just go pick 'em up....
2004 Mercury Grand Marquis GS
1999 VW New Beetle SOLD!
click here to check 'em out.
RedThunder94 is offline
post #12 of 15 (permalink) Old 11-18-2004, 08:21 PM
If you're really looking to save a buck, go to the body shop and discuss ways you can save money. remember that the estimate is full of nickel-dime $hit that you can do yourself. It does need some time with a frame guy, but the frame dept will get at least one hour labor for frame setup alone. if youve ever seen it done youll know why. expect 2-3 hrs labor for the work. have them install the fenders only and hold them responsible for producing real nice hood gaps. tell them youll deal with the lights, bumper, header panel, all paint work. try to get a solid, barebones written estimate.
And if the guy gives you any crap at all, pick another shop. one that appreciates customers through the door. you might even negotiate the labor rate paying cash.
Good luck.
modbird is offline
post #13 of 15 (permalink) Old 11-18-2004, 09:35 PM Thread Starter
Motorboatin' SOB
big mike's Avatar
yeah, the guy said about 4 hours total to setup and pull and square the frame rails and bumper. how will they line up the fenders to fix the hood gaps? is this something that is done on a frame bending machine?
2014 GT
1990 300ZX TT
big mike is offline
post #14 of 15 (permalink) Old 11-19-2004, 08:47 AM
jk69cat's Avatar
mike they may go back once the frame is pulled. otherwise they have to adjust the fenders
mn12 less!
jk69cat is offline
post #15 of 15 (permalink) Old 12-04-2004, 08:42 PM Thread Starter
Motorboatin' SOB
big mike's Avatar
here are some pics of the frame rails and the metal bumper.
passenger side
driver side
metal bumper damage
i went to another shop and they told me they have a rate of $38 an hour. my car will spend 4-5 hours on the frame bending machine. they would prefer that i leave the bumper cover on so that everything lines up once the frame bending is done.
2014 GT
1990 300ZX TT
big mike is offline
