Shocks on F-glass Hood - TCCoA Forums
post #1 of 4 (permalink) Old 11-21-2004, 01:14 PM Thread Starter
97TBirdGirl's Avatar
Send a message via AIM to 97TBirdGirl Send a message via Yahoo to 97TBirdGirl
Question Shocks on F-glass Hood
I've heard that the stock hood shocks mess up a fiberglass hood (push up on the back and cause 'bad' pressure on it) and that you cant use them, and I've heard you can. I figured yall would know better than anyone. Also, I dont know if all t-bird hoods are like this or not but their not the easiest things to close. You kinda have to learn how to close them or they dont latch on the first try...Anyways, yalls feedback would be great...
Tiff
97TBirdGirl is offline
post #2 of 4 (permalink) Old 11-21-2004, 01:51 PM
96bird's Avatar
Here is a website that people with 'glass hoods might want to look into.
Redline
Maybe you could talk to these guys about frabicating some struts for us. I have heard to be careful with the stock hood struts and 'glass hoods...maybe you just need some worn out stock hood shocks. I hope that helps.
Russell
96bird is offline
post #3 of 4 (permalink) Old 11-21-2004, 04:57 PM
tony8470's Avatar
My cervinis has the stock mounting bosses for the shocks, and they are mounted as well. I havent seen and cracking in the 1 1/2 years I've owned it. I dont throw it open or closed either, take care of it and it will take care of you. Im sure cervinis wouldnt have put them there if they knew they would be getting reutrns from their hoods cracking under the pressure.
1990 35th anniversary T-bird SC
1993 Mercury Cougar 3.8
tony8470 is offline
post #4 of 4 (permalink) Old 12-08-2004, 05:44 PM
I've had a design concepts hood for ummmmm 3.5 years now with brand new hood shocks on it. No problems or anything.
RedBirdSC is offline
