problems w/ door - TCCoA Forums
post #1 of 10 (permalink) Old 11-28-2004, 05:40 AM Thread Starter
problems w/ door
my driver side door will not shut all the way and the two metal latches sometimes bounce right off the little bar they close on to...it also stripped that plastic layer that was over the metal bar and i want to get this fixed so the car does not start looking ghetty...tried wd40, slamming the hell out of the door, and messing with the latches, any other advice? thanks
chromecoupe is offline
post #2 of 10 (permalink) Old 11-28-2004, 10:26 AM
go get a spray can of white lithium grease and spray it on the latching mechanism in the door. Soak the hell out of it, wait a while, then spray it some more, than clean up the door jamb. That will probably fix it, but if not it should at least help a little.
Mike
post #3 of 10 (permalink) Old 11-28-2004, 03:59 PM
you need a new lower hinge assembly. you can use a pin repair kit, but just get the hinge, brand new, then get a new striker. it will come with the nylon sleeve.
When the door is open, grab the door and lift it. you will see a lot of play up and down. lower hinge is usually the culprit, and far easier to swap out than the upper one. Do not let the door just bounce off the striker, it WILL crack the sheetmetal in the jamb area, and that is not fun to fix.
97 Mark VIII LSC yeah
08 Ford Edge, white for now
modbird is offline
post #4 of 10 (permalink) Old 11-28-2004, 05:19 PM Thread Starter
i dont think its the hinges or upper/lower pins...the door sits pretty centered but just where it latches onto the rod to shut it is not going on all the way...is it just because that plastic or nylon sleeve that was on the rod is gone? i see three screws near the latches on the door and one for the rod that has a torx bit, would fabricating some type of sleeve help any? thanks
post #5 of 10 (permalink) Old 11-28-2004, 08:55 PM
Rolling-Thunder's Avatar
You can adjust the position of the striker bolt (the one with the plastic sleeve on it)
Just loosen it and slide it out a tad. Maybe it is in too far for the hook to fully engage.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #6 of 10 (permalink) Old 11-28-2004, 09:01 PM
..go to the junk yard and get one with the nylon sleeve from a tbird.....that's what I did and the door now closes. properly.
z
90s/c,MPII blower & plenum,CMRE Stg 1 heads/cam,3/4 raised top,85mm MP TB,42# injectors,85mm ProM MAFS,MP CAI,Kooks mids w/3" mid pipe & Magnaflows, AOD w/trans-go,trans-cooler,373's, SCT Chip tuned by Ed Clark,10% SC pulley,5% JS pulley,ASP u/d pullies,MP FMIC,AADCO 1 3/8" swaybars,clear corners,Eibach prokit.....BLOWN UP......ANYONE NEED PARTS........now have 2 MRK VIII's
z90sc is offline
post #7 of 10 (permalink) Old 11-28-2004, 09:48 PM Thread Starter
are they all the same size? will a 92 go into a 97?
post #8 of 10 (permalink) Old 11-30-2004, 11:36 AM
Don't adjust the striker, that is bad voodoo....
Can you lift up on the door? It sounds liek classic signs of time to replace your striker and door pins.
Here is a link to when I did mine, and now it is perfect. Very easy to do.
http://forums.tccoa.com/showthread.p...threadid=53362
sc0tty8 is offline
post #9 of 10 (permalink) Old 11-30-2004, 01:25 PM
Why do you think they made the striker adjustable?
He said that he didn't think it was the hinge pins, as the door seems to line up properly. Maybe the striker bolt has shifted inwards, thus causing the latch hook to hang.
post #10 of 10 (permalink) Old 11-30-2004, 01:33 PM
Fine adjust striker, but if the plastic is worn off of it, it is not the striker that needs to be adjusted or replaced. It would be obvious that the door sags or a bushing is worn.
sc0tty8 is offline
