thunderbird lx removal - TCCoA Forums
post #1 of 20 (permalink) Old 12-08-2004, 08:29 PM Thread Starter
what is the best way to shave off the lx emblem on the back of the car? its a 97 and i want to keep thunderbird on there. anyone ever tried or done this? thanks.
robbie is offline
post #2 of 20 (permalink) Old 12-08-2004, 08:51 PM
8ate8's Avatar
Send a message via AIM to 8ate8
pretty sure you'll have a hole behind where the LX is. don't remember when i took my badge off. but if there isn't a hole, you can just remove the hole badge and then just saw off the LX.
Jersey Rice
NJ Thunderbird & Cougar Club
Sold '96 Thunderbird LX 3.8l :: Cardomain Page
'93 Thunderbird SC 3.8l - 12 second car. 14 second driver.
'05 Toyota X-Runner
8ate8 is offline
post #3 of 20 (permalink) Old 12-09-2004, 09:49 AM
Rolling-Thunder's Avatar
Best way is to take a piece of very thin wire, or fishing line, and saw it off, between the glue tape and the emblem.
Use it kinda like dental floss.....lol
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #4 of 20 (permalink) Old 12-09-2004, 10:31 PM
robbie:
I'm collecting new goodies for my upcoming full-paint job in the spring, and have in my hot little hand a new "Thunderbird LX" emblem for a 96, still in the plastic bag. If you pull your whole emblem off, you will find 3 pins about 1/8" in diameter:
- one at the top of the T where the vertical and horizontal bars meet;
- one at the junction of the R and the B;
- one at the bottom of the L, in the thickest part.
Near as I can tell, the pins (and matching holes in the trunk lid) are simply an alignment aid for assembly, as the emblem itself is retained by industrial-strength double-sided tape.
Hope this helps,
Larry W7LES in Cheyenne
Larry W7LES is offline
post #5 of 20 (permalink) Old 12-10-2004, 07:00 AM Thread Starter
thanks everyone for the input on this that will get me started in the right direction.thanks again rob.
robbie is offline
post #6 of 20 (permalink) Old 12-10-2004, 07:15 AM
Someone should probably mention to use either Goo Gone, Goof off, or clear nail polish remover (the kind with acetone) to get rid of the tape residue.
post #7 of 20 (permalink) Old 12-10-2004, 07:35 AM
JustinH's Avatar
dental floss, then repaint the decklid.
Just kiddin, some goo gone works well.
JH
JustinH is offline
post #8 of 20 (permalink) Old 12-11-2004, 12:31 AM
MaleWhore
smokymance's Avatar
what u guys do about the holes on the trunk lid?
smokymance is offline
post #9 of 20 (permalink) Old 12-11-2004, 10:31 AM
JustinH's Avatar
there are no holes behind the thunderbird lx emblem, its just a sticker.
the ford emblem has holes behind it, thats why i left mine on.
JH
JustinH is offline
post #10 of 20 (permalink) Old 12-11-2004, 10:34 AM
MaleWhore
smokymance's Avatar
i didnt know that...i thought there were
post #11 of 20 (permalink) Old 12-11-2004, 12:13 PM
$.25 poster
AlpineBird's Avatar
Send a message via AIM to AlpineBird
JH
there are DEFINETLY 3 holes behind the Thunderbird LX script, and they will need to be filled unless you want your trunk to leak
'96 Alpine Bird 281ci
- Clear Corners
- DynoMax Cat-Back
- Purchased with 36,000 miles, now at 101k
- No mods planned untill it's DD life is over
1998 5.9 Limited Grand Cherokee
- Flowmaster Exhaust
- AEM Brute Force Intake
- Mopar Performance ECU
- 275hp-395ft/lbs at the crank (est.) Track results in the spring!!!
AlpineBird is offline
post #12 of 20 (permalink) Old 12-11-2004, 12:22 PM
JustinH's Avatar
mine was just a sticker, I removed the logo and there were no holes.
I suppose mine had a replaced lid at one time then.
JH
JustinH is offline
post #13 of 20 (permalink) Old 12-11-2004, 12:30 PM
MaleWhore
smokymance's Avatar
i checked mine from inside the trunk...and yes...there are 3 pins coming out of the enemblem it self
post #14 of 20 (permalink) Old 12-11-2004, 05:20 PM
motor city poster
Red96Bird's Avatar
so go get a 94/5 trunk lid, put on ur 96/7 lights, paint it, and then there will be no script on the back
Red96Bird is offline
post #15 of 20 (permalink) Old 12-12-2004, 03:19 AM
my 93 only had holes behind the ford logo. bondo and paint fixed that up. Nothin behind the thunderbirdLX sign... Hair dryer took that sign off no problem
ITHURTZ is offline
post #16 of 20 (permalink) Old 12-12-2004, 11:33 AM
8ate8's Avatar
your 93 also doesn't have the logo on the decklid. it's on the taillight, so of course there would be no holes behind it.
Jersey Rice
'05 Toyota X-Runner
8ate8 is offline
post #17 of 20 (permalink) Old 12-12-2004, 11:54 AM
Here is what I know FOR SURE.
My 96 T-Bird was heavily vandalized in the rear, apparently the tool of choice was a ball-peen hammer. I’m collecting parts to reassemble it after a full repair and repaint in the spring.
My 96 trunk lid was so badly damaged that I purchased a replacement lid off a 93 T-Bird from the local wrecking yard. This 93 lid has been completely disassembled, all that is left on it is the old paint.
The 96 lid has the script “Thunderbird LX” emblem on the left side, above the LED lightbar reflector. It is held in place with double-stick tape and has 3 alignment pins that fit into 3 matching alignment holes on the lid.
The 93 lid did not have a Thunderbird emblem on the left side of the trunk lid. I believe that the 93 used a block-letter “THUNDERBIRD” emblem attached along the lower edge of the left LED lightbar reflector. I would say that a stick-on on the LED lightbar would not use alignment pins and holes. It appears that the LX cars got a second, small block-letter "LX" emblem, also a stick-on, that went to the right of the main THUNDERBIRD emblem.
I have purchased a new 96 script “Thunderbird LX” emblem for my car, to be installed after the repainting is completed. It has the 3 alignment pins on it on the back side, as I wrote in the forum earlier. I will have to drill the 3 small alignment holes, for the 96 emblem, in the 93 lid prior to painting.
You can check for the alignment pin holes on your car very easily. Open the trunk lid and feel along the inside of the lid, through the openings behind the emblem. Your 97 will almost certainly have the 3 alignment pins and holes.
I'm not sure when the script "Thunderbird LX" emblem was moved to the trunk lid. It looks like it was after 93, I'm thinking it was on the 95-97 cars. Anyone want to chime in with info on the 94 cars?
post #18 of 20 (permalink) Old 12-12-2004, 03:06 PM
ah my bad.
ITHURTZ is offline
post #19 of 20 (permalink) Old 12-12-2004, 05:31 PM
8ate8's Avatar
96/97 has the script on the decklid. 92-95 had it on the taillight.. 89-91, actually, idk where it said thunderbird..
Jersey Rice
'05 Toyota X-Runner
8ate8 is offline
post #20 of 20 (permalink) Old 12-16-2004, 03:32 PM
Shaving it on a 94 was easy...
I used the high "e" sting from my guitar, and some goo-gone
tsbird1994 is offline
