Painting Exterior Trim - TCCoA Forums
post #1 of 6 (permalink) Old 12-10-2004, 05:02 PM Thread Starter
Exclamation Painting Exterior Trim
Is it possible to paint the black/grey fade around the side mirrors and the black bar that travels between the doors and the quarter windows the same color as your car? Would it look right? Prep?
Nightmist_Outlaw is offline
post #2 of 6 (permalink) Old 12-10-2004, 05:07 PM
Jedi Master
mn12xr7's Avatar
the section circled is covered by vinyl that can be removed....i have mine removed i think it looks better like that
-Orlando
mn12xr7 is offline
post #3 of 6 (permalink) Old 12-11-2004, 04:29 AM
Cant even see that mn12xr7. Too dark.
Work needed to be done: Heater Core Replaced; Driver Door panel replaced; Right Inner tie rod replaced; Front suspension rotting away; Wire connection to the transmission melted from contact with exhaust.
TimberWolf is offline
post #4 of 6 (permalink) Old 12-11-2004, 11:30 PM
Fry Rice Specialist
Casper's Avatar
the side mirror one i want to redo also but once taken out couldn't figure out how to take apart the side view mirror from the bracket.
CarDomain Page
Casper is offline
post #5 of 6 (permalink) Old 12-24-2004, 08:03 PM
Audiobahnbird's Avatar
Send a message via AIM to Audiobahnbird
reverse torx bits, good luck finding one small enough.....
Please enjoy my new and improved short signature- Russ
Audiobahnbird is offline
post #6 of 6 (permalink) Old 12-25-2004, 04:21 PM
as far as prep goes, sand with 600/800, or grey scotchbrite. clean, base, then clear. it'll look like it came that way. I didnt do the black window channel, but I did do the mirrors on mine, and it looks a lot better all the same color. If you want them painted for you, just lemme know.
97 Mark VIII LSC yeah
08 Ford Edge, white for now
modbird is offline
