Thunderbird emblem removal question - TCCoA Forums
post #1 of 5 (permalink) Old 10-09-2002, 02:28 PM
ice_nyne
Guest
Posts: n/a
I imagine J-Rob will know the answer to this:
On a '96 Thunderbird, is the "Thunderbird LX" script on the trunk bolted on, or is it merely double-sided tape. I'm hoping to remove it using the old fishing line method, and a little clay magic to clean up the leftover residue. Somebody let me know if it's indeed as easy as that.
ice_nyne
post #2 of 5 (permalink) Old 10-09-2002, 02:43 PM
8ate8's Avatar
Send a message via AIM to 8ate8
mixture of both.. there's double sided tape on it, but there's also prongs sticking out the back of it that go into the trunk.. those aren't bolted in, but if you take the badge off, there's gonna be 2 (3?) holes left behind.
Jersey Rice
NJ Thunderbird & Cougar Club
Sold '96 Thunderbird LX 3.8l :: Cardomain Page
'93 Thunderbird SC 3.8l - 12 second car. 14 second driver.
'05 Toyota X-Runner
8ate8 is offline
post #3 of 5 (permalink) Old 10-09-2002, 03:06 PM
Refrigerator Raider Hater
GreenBird's Avatar
fishing line has never worked for me, it always snaps.
I remove emblems with a razor and acetone. use the razor to cut the tape in the foam section, then use the acetone to remove the tape from the paint (it didn't hurt my 89 or 91's paint, but use at your own risk). Just make sure to wax the area after because acetone will remove all wax.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #4 of 5 (permalink) Old 10-12-2002, 11:19 AM
need to get yourself some of that 10lb spider line... now that's some good fishin line.... mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm mmmmmmmmmmmmmmmmmmmmmmmm
smokey7 is offline
post #5 of 5 (permalink) Old 10-13-2002, 10:39 PM
it leaves three holes .... USE A HAIR DRYER TO LOOSEN IT AND STICK A LONG SCREW DRIVER IN THE HOLE IN THE TRUNK TO PUSH THE PRONGS OUT FROM THE BACK. then fill the wholes with body puddy and paint
good luck
andrwe
TBird 38 LX is offline
