What causes headlights to turn yellow? - TCCoA Forums
post #1 of 15 (permalink) Old 01-10-2005, 01:19 AM Thread Starter
Up until recently i thought the sun was the major reason for the headlights turning yellow.
But today when i went to buy the materials needed to try to clean the headlights the pep boys guy there told me i was completely wrong. He said the cause is from the bulb in the inside of the headlights. He also said that the only way to clean it is from the inside and not the outside.
So is the pep boy guy right or wrong?
Decimator13 is offline
post #2 of 15 (permalink) Old 01-10-2005, 01:24 AM
Banned
HAHAHHAHAHAHA!!!!!!!....ROFL!!...
man thanx i needed that...yes it is caused from the outside..actually the lens is cleaner on the inside than the outside..clean off the outside lens..and if you really ARE hardcore about it take apart the lens from the headlight housing and scrape the old glue out and re-seal it with clear silicone..looks like new...
someone needs to talk to big mike
-Mike
Porkchop is offline
post #3 of 15 (permalink) Old 01-10-2005, 03:25 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
hes way ahead of you, mikey alex, you should have slapped that pep boys fool like a dirty whore. dont listen to any pep boys, autozone, etc. employees, most of them dont know their *** from a hole in the ground.
2014 GT
1990 300ZX TT
big mike is offline
post #4 of 15 (permalink) Old 01-10-2005, 05:58 AM
JustinH's Avatar
uv rays make the headlights yellow. They get yellow because people don't wax their headlights and protect them.
JustinH is offline
post #5 of 15 (permalink) Old 01-10-2005, 06:14 AM
Raoul Duke
cougarcragar's Avatar
I agree, but here's the big question:
Why aren't the corner lenses affected?
If the above is true and heat from nighttime driving isn't a factor, then there must be two different platics.
1996 Mercury Cougar XR7
cougarcragar is offline
post #6 of 15 (permalink) Old 01-10-2005, 07:16 AM
Rolling-Thunder's Avatar
I would agree that the material is different.
My headlights didn't yellow because I kept the black GTS covers on them.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #7 of 15 (permalink) Old 01-10-2005, 08:47 AM
I had black GTS covers on mine and they turned yellow to a point to where I had to buy a new headlight.
That was before i discovered this stuff
http://www.autobarn.net/memiglclplcl.html
and this
http://www.autobarn.net/memiglclplpo.html
This is great stuff. Try this and it should take care of your problem as long as you havn't let it go to long.
Thunderchick94 is offline
post #8 of 15 (permalink) Old 01-10-2005, 09:07 AM
mamberg's Avatar
Hey, I take offense to that!!!
I know you said 'most', but first you said 'any'..............................
And if you think the employees are stupid, you should experience the intelligence of the average customer!!!!
The statements in this post are my opinions only.
If you have a problem with them, please PM me
and keep the boards clear of flame wars.
_____________________________________________
mamberg is offline
post #9 of 15 (permalink) Old 01-10-2005, 10:14 AM
Cool
In this forum, go to the Sylvania Xtra Vision thread. There are some suggestions there on how to clean your lenses. Ulta violet light is the culprit as well as poor maintance. They need to be cleaned and waxed on a regular basis just the same as your car.
Have Fun!!
Uncaged 94 is offline
post #10 of 15 (permalink) Old 01-10-2005, 10:18 AM
Who is John Galt?
"Won't work, can't be done"
cougar_guy04 is offline
post #11 of 15 (permalink) Old 01-10-2005, 11:38 AM
$.25 poster
AlpineBird's Avatar
Send a message via AIM to AlpineBird
just remeber when your going through your stuff to find what you wanna wax them with.....
If its wax.....use it
If its polish....dont
Polish removes the uv pretection stuff coated on the headlights and speeds up the yellowing process and thats the last thing you need on a set of tbird headlights
'96 Alpine Bird 281ci
- Clear Corners
- DynoMax Cat-Back
- Purchased with 36,000 miles, now at 101k
- No mods planned untill it's DD life is over
1998 5.9 Limited Grand Cherokee
- Flowmaster Exhaust
- AEM Brute Force Intake
- Mopar Performance ECU
- 275hp-395ft/lbs at the crank (est.) Track results in the spring!!!
AlpineBird is offline
post #12 of 15 (permalink) Old 01-10-2005, 02:59 PM
Motorboatin' SOB
big mike's Avatar
oops, sorry. i meant to say dont listen to any autozone, pep boys, etc. employees except the ones that post here
2014 GT
1990 300ZX TT
big mike is offline
post #13 of 15 (permalink) Old 01-11-2005, 09:41 AM
Johnny Bling Bling
93 lx's Avatar
busted
2009 Ford Flex Limited AWD
93 lx is offline
post #14 of 15 (permalink) Old 01-13-2005, 01:29 PM
It has been my experience, I could be wrong though, that the reason the headlamp covers turn yellow is not keeping them clean. The heat from the lamps seems to bake the grime into the lense. My wifes car had the plastic lenses, one replaced due to accident and the other could not be cleaned to matched. Body shop told me this.
carld83 is offline
post #15 of 15 (permalink) Old 01-13-2005, 02:17 PM
Polish is going to help if the headlights are already yellow. Then you put wax on to protect.
