Clear Coat - TCCoA Forums
post #1 of 7 (permalink) Old 01-15-2005, 03:14 PM Thread Starter
Sideoiler's Avatar
Clear Coat
Assuming the original paint is good on a vehicle but the clear is scratched (but not through the paint). Could you lightly wet sand and feather the areas and then just spray some light coats of clear over the areas that are marred, let it dry and buff it out? Or, would it be feasable to lightly sand the whole car and do a new clear coat? BTW/ color is opalessent (or pearl as some call it) and I understand it's a pita and mucho $$$ to do a new paint job.
Sideoiler is offline
post #2 of 7 (permalink) Old 01-15-2005, 04:30 PM
nope if you try to feather the clear you will burn through the base. better off to sand the whole car seal it and shoot it. darrell
thunderbirdgod is offline
post #3 of 7 (permalink) Old 01-15-2005, 04:33 PM Thread Starter
Sideoiler's Avatar
Sooot it?
Seal it with what? And shoot it with paint or with clear? Thanks for the reply.
post #4 of 7 (permalink) Old 01-15-2005, 05:07 PM
If they are just light scratches you can wetsand them with 1200 grit, and then have the affected area re-cleared. Then wetsand it lightly with 1200-1500 afterwards, overlapping with the old clear, and then buff it out. Make sure you only go deep enough to get the scratch to where you can't feel it, and going into the paint just a touch won't hurt it, as long as you don't go all the way through.
Rich95XR7 is offline
post #5 of 7 (permalink) Old 01-15-2005, 05:14 PM Thread Starter
Sideoiler's Avatar
Thanks Rich!
That's the answer I was looking for. I think it will be OK if I'm really careful.
Sideoiler
post #6 of 7 (permalink) Old 01-15-2005, 05:16 PM
JustinH's Avatar
the front bumper on my car was just re-cleared, it has the original paint on it. The hood has new paint though.
JustinH is offline
post #7 of 7 (permalink) Old 01-15-2005, 05:38 PM
NUHBOY4.6's Avatar
Send a message via AIM to NUHBOY4.6
lots of warm soapy water and a couple clean pieces of sand paper. i would hit the areas that need love and spend the majority of time highspeed buffing it all together. make sure you also have a heavy orbital buffer to smooth out the swirl marks before you wash it all down. i would really try avoiding reclearing anything. if you spend time buffing with a quality product there is really no reason you should have to clear anything. i have done this to numerous cars, including the bird, that were hammered from acid rain. the people wanted a new paint job but after i had it for a couple of hours, it was glass.
***image removed from signature due to rule violation***
NUHBOY4.6 is offline
