Door Catch Broke - TCCoA Forums
post #1 of 7 (permalink) Old 01-19-2005, 08:14 AM Thread Starter
Door Catch Broke
The passenger door catch (welded to the door jam) on my 95 bird broke away from the body. Anybody had this happen or have an idea how to get it fixed on the cheap?
jaushaug is offline
post #2 of 7 (permalink) Old 01-19-2005, 11:03 AM
Trumpeter Extraordinaire
IronChopz's Avatar
It's happened on the driver's side on my car...I'm shopping around for a welder guy to fix it. As far as it being cheap? Seems to me around my area, $100 is what it'll take to weld and reinforce it properly.
IronChopz is offline
post #3 of 7 (permalink) Old 01-19-2005, 01:21 PM Thread Starter
thanks. i'll let you know if i find a cheaper fix.
jaushaug is offline
post #4 of 7 (permalink) Old 02-09-2005, 07:34 PM
Send a message via AIM to Trick Bird
I have that on my drivers side right now.
95' lx 4.6
true dual exhaust, mass air, 9 in k&n, 3:73 posi, 9mm ford racing wires, screamin demon coils, solid rubber trans mount, cobra r hood, clear corners, chrome bullit replicas.
Trick Bird is offline
post #5 of 7 (permalink) Old 02-10-2005, 10:11 AM
Rolling-Thunder's Avatar
Seems to be a common problem with our cars. Mine is cracked all the way thru on three sides around the drivers side strike bolt. The metal is extremely thin.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #6 of 7 (permalink) Old 02-10-2005, 06:26 PM
I fived mine bu cutting some heavy guage steel from a F150 bumper, flattened it out, drilled a hole in the middle of it and welded it on. smoothed it flush, right before the paint job. doesnt cost much, just need no know someon who welds.
97 Mark VIII LSC yeah
08 Ford Edge, white for now
modbird is offline
post #7 of 7 (permalink) Old 02-11-2005, 09:08 PM
thunderbird96's Avatar
Send a message via AIM to thunderbird96 Send a message via MSN to thunderbird96 Send a message via Yahoo to thunderbird96
I just fixed my driver door one in autobody class. The best way is weld it up from the front. make sure you replace the door hinge pins for a good repair. my teacher said the sagging door hinges causes the strikers to tear the metal over time.
thunderbird96 is offline
