Difference between a Sunroof / Moonroof? - TCCoA Forums
post #1 of 27 (permalink) Old 02-09-2005, 10:36 PM Thread Starter
Just curious, thats all.
I wanted to also know the price differences and what not.. I've always wanted one, could be a great B-day present
Thank you,
John
1997T-Bird is offline
post #2 of 27 (permalink) Old 02-09-2005, 11:33 PM
TCCoA Founder
Sir William's Avatar
Well, I've never seen an aftermarket moon roof, only sunroofs. If you don't know the difference, a sunroof is a glass panel that can be tipped up to let air in/out. A moonroof can slide back out of the way and be totally open.
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #3 of 27 (permalink) Old 02-10-2005, 12:24 AM
tyman00's Avatar
Sunroofs/Moonroofs can be sheetmetal as well.... but they are so much more boring.
tyman00 is offline
post #4 of 27 (permalink) Old 02-10-2005, 12:48 AM
Tom
I have never seen a erm.... glass-roof ... .... that can't do both of those. What is the accurate name for the one that does both?
Tom is offline
post #5 of 27 (permalink) Old 02-10-2005, 01:47 AM
From Wikipedia
sunroof
A sunroof is a cutout in a car's (or truck's) roof that can be opened to provide fresh air and sun to the people inside. A sunroof can be made of the same metal as the rest of the roof, or it can be made of plastic and transparent (usually tinted), in which case it customarily referred to as a moonroof. Moonroofs have a sliding shade in the interior that can be retracted, and were invented by the American Sunroof Company.
Sunroofs can be manual or electric. Manual sunroofs usually work by flipping up to create a small opening around the edges, or being removed completely. Electric sunroofs either flip up and slide back on top of the roof, or down and into the roof. An electric sunroof will have access to close it manually if the motor or control circuitry fails.
All moonroofs are sunroofs, but not all sunroofs are moonroofs.
See if you can find a dealer/installer for Inalfa/American Sunroof Corporation (ASC). I believe that they are the "inventors" of the auto sunroof [I read it on the internet (see above def.), so it must be true ]. This page from a Cali dealer has pictures of some of their products.
I also found this contact info:
From LS1TECH.com
ASC Incorporated
ASC, Incorporated
One Sunroof Center
Southgate, MI 48195
TEL: (734) 285 4911
FAX: (734) 246-2735
SUNROOFS/AFTERMARKET ACCESSORIES
American Sunroofs Inalfa
747 Advance Street
Brighton, MI
1-800-521-9753
I haven't contacted a local ASC dealer yet for prices, but the cheapest option would definitely be a manual pop-up sunroof. I've seen prices between $150-250, plus install.
Motorized sunroofs are probably a few hundred dollars more. Street Beat Customs lists some ASC spoiler-style models between $330-500. That's for the sunroof alone. I don't know what labor will cost, depends on the installer.
I haven't looked into any other manufacturers, but Google is your friend.
Astaeroth is offline
post #6 of 27 (permalink) Old 02-11-2005, 07:44 AM Thread Starter
These prices aren't bad.. Would the installer have to cut a hole into the sunroof? Or do i replace the entire roof on the car?
post #7 of 27 (permalink) Old 02-11-2005, 10:33 AM
Raoul Duke
cougarcragar's Avatar
Astaeroth is correct.
In general terms, a moonroof can be glass or metal, but it's one that slides internally, or under the roof.
A sunroof can be flip-up, or it can slide back over the roof (Cavalier/Sunfire, Sebring/Eclipse) and is usually called a "spoiler sunroof".
I had a 17x32" flip-up installed for $320. It included a lifetime warranty on everything except glass breakage.
I could have had an electric spoiler installed for $750...
There was also a "topslider sunroof" (probe, MX-6), but they have been discontinued.
1996 Mercury Cougar XR7
cougarcragar is offline
post #8 of 27 (permalink) Old 02-11-2005, 11:12 AM Thread Starter
So the manual sunroofs can be completely removed for when it is nice out?
post #9 of 27 (permalink) Old 02-11-2005, 01:39 PM
$.25 poster
AlpineBird's Avatar
Send a message via AIM to AlpineBird
yes, but always carry it with you. I remember when i was little my mom's probe had a sunroof and we went out once on a sunny day and left the glass in the garage, during our time on the road the sun went away and it started to rain. Needless to say our day ended early.
'96 Alpine Bird 281ci
- Clear Corners
- DynoMax Cat-Back
- Purchased with 36,000 miles, now at 101k
- No mods planned untill it's DD life is over
1998 5.9 Limited Grand Cherokee
- Flowmaster Exhaust
- AEM Brute Force Intake
- Mopar Performance ECU
- 275hp-395ft/lbs at the crank (est.) Track results in the spring!!!
AlpineBird is offline
post #10 of 27 (permalink) Old 02-16-2005, 08:23 PM Thread Starter
What about the little overhead light? Where does that go?
Can you buy this stuff from Dan N.?
post #11 of 27 (permalink) Old 02-17-2005, 09:46 PM
Teal94BirdV8's Avatar
Send a message via AIM to Teal94BirdV8 Send a message via Yahoo to Teal94BirdV8
My..uhh...window in the roof slides internally under the roof, AND flips up...
94 LX V8 & 93 SC gone. Not forgotten.
1992 Lincoln Mark VII LSC Cobra U/L intake, PP 65mm TB, Powerdyne BD-11 8#, Walbro 255, FRPP 30lb Injectors, MSD ignition, 3.8 Taurus E-fan, A9P MAF conversion, Pypes 1&5/8" Shortys, O/R H-Pipe, 4.10 Trac-Lok, T-5 swap, FRPP flywheel, Ram HDX clutch, Steeda Clutch kit
2002 F150 FX4 Lariat 6" Fabtech, 3" BL, Stock FX4 wheels, 37x12.50 Nitto Trails, Yukon 4.56s, Detroit TrueTrac, Edge Evo, 8K HIDs, PowerStop truck&tow kit
1996 GMC Suburban SLT 6K HIDs, crystal clear light set, daily beater @ 222k miles
Teal94BirdV8 is offline
post #12 of 27 (permalink) Old 02-18-2005, 12:05 AM
Whining Intakes Rock
Al_Florida's Avatar
Time of day.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #13 of 27 (permalink) Old 02-18-2005, 12:42 AM
Probes had awesome Moonroofs. Mine did anyway
NiteFire is offline
post #14 of 27 (permalink) Old 02-19-2005, 01:38 PM
Sideoiler's Avatar
Time of day.
Darn! Beat me to the punch again! Was just gonna say; When the sun is shining down on me, it's my "sunroof". At night, when the moon is out; It's my "moonroof". Either way, I like it a he*l of a lot and use it when the weather's right. I find it especially usefull for transporting my giraffes.
Sideoiler is offline
post #15 of 27 (permalink) Old 02-19-2005, 03:29 PM
Raoul Duke
You misread my post. You have a moonroof because the glass slides under the roof in the open position. All sunroofs/moonroofs flip up (vent position). A power sunroof slides back above the roof.
post #16 of 27 (permalink) Old 02-19-2005, 06:49 PM
SVT2888's Avatar
Send a message via AIM to SVT2888
Last time I saw a 99 mustang V6 with a Plexiglass sunroof. It was super pimp my ride cause it was obvioulsy home made. They just cut a hole in the roof, layed a piece of plexiglass on it and put some silicone caulking around it.LOL.
Mods: Concrete Median
CNCpics.com-Automotive Event Photography
Facebook
Ebay Store
Official B-team member. Viva La Revolucion!
SVT2888 is offline
post #17 of 27 (permalink) Old 02-19-2005, 09:45 PM
Audiobahnbird's Avatar
Send a message via AIM to Audiobahnbird
pimp my ride is a horrible, horrible program
Please enjoy my new and improved short signature- Russ
Audiobahnbird is offline
post #18 of 27 (permalink) Old 02-19-2005, 10:11 PM
Al_Florida's Avatar
Originally Posted by Sideoiler
...I find it especially usefull for transporting my giraffes.
Must suck if you forget to train them to duck when approaching a bridge.
# 0 rows returned
post #19 of 27 (permalink) Old 02-20-2005, 12:29 AM
SVT2888's Avatar
hope to never see an MN-12 on pimp my ride.
Facebook
Ebay Store
SVT2888 is offline
post #20 of 27 (permalink) Old 02-20-2005, 07:21 PM
post #21 of 27 (permalink) Old 02-20-2005, 07:39 PM
SVT2888's Avatar
Facebook
Ebay Store
SVT2888 is offline
post #22 of 27 (permalink) Old 02-22-2005, 08:55 AM Thread Starter
What about the overhead light when you sit in the car? The sunroof would be right where that is at, would the install include them moving it somewhere else??
post #23 of 27 (permalink) Old 02-22-2005, 09:50 AM
The Saturn IONS have the topslider moonroof now
NiteFire is offline
post #24 of 27 (permalink) Old 02-22-2005, 10:14 AM
Raoul Duke
I meant they were discontinued in the aftermarket world.
It's nice to see that GM is bringing it back... very cool sunroof.
post #25 of 27 (permalink) Old 02-22-2005, 10:24 AM
my '92 base had a aftermarket, non-electric, removable sunroof/moonroof. the location of the Map light was moved to inbetween the visors, just like a mn12 with a factory moonroof does.
and yes, if you get a removable, always keep it with you, i layed mine vertically behind the pass seat. i used to leave it in the trunk, bungee cordered to underside of the rear deck--but it was inconvent--and well i had an experience one day with the rain while in heavy traffic & stuck in the far left lane of a 4 lane highway.
and just a note: you will notice increased chassis flex with a aftermarket piece.
tomaso12 is offline
post #26 of 27 (permalink) Old 02-22-2005, 11:18 AM Thread Starter
I was expecting as much..
But I can live with it. Is Chasis flex REALLY bad?
post #27 of 27 (permalink) Old 02-22-2005, 12:26 PM
the increased chassis flex really is not that bad. i only noticed it around certain corners, at low speed. nothing to worry about though. However i should warn, that once you put a hole in your roof your gonna want one in every car you own
tomaso12 is offline
