Rattle Can Job - TCCoA Forums
post #1 of 45 (permalink) Old 02-16-2005, 12:37 PM Thread Starter
ECU_Q's Avatar
Send a message via AIM to ECU_Q
Rattle Can Job
I was doing some searching last night for pictures of rattle can jobs, but the pictures sort of....vanish if the thread is old. So does anyone have pictures of a rattle can job that worked out for them and can they share any tips. Thanks alot.
ECU_Q is offline
post #2 of 45 (permalink) Old 02-16-2005, 01:06 PM
drag-aholic
BAGGED89's Avatar
rattle can the outside? on a 2 stage paint job just my
1989 LX Full Air Suspension
BAGGED89 is offline
post #3 of 45 (permalink) Old 02-16-2005, 01:18 PM Thread Starter
ECU_Q's Avatar
If I am able to show you some pics then you'll understand, and its not the whole car anyway, just the roof. Theres bascially no paint up there.
ECU_Q is offline
post #4 of 45 (permalink) Old 02-16-2005, 01:25 PM
I'm going to do the same thing on my rusted Cougar top and I had planned on using this company: http://www.levineautoparts.com/spraycanofto.html
I don't know anything about them, but all I want is some paint...
69 F100 LWB w/460 Engine
post #5 of 45 (permalink) Old 02-16-2005, 01:46 PM
drag-aholic
BAGGED89's Avatar
is it the money keeping you from using real paint? You could get a quart of paint and some clear, even if it was a lower line like Omni, i would suggest the result would be better and last longer than a rattle can. I don't know how you will get any thickness out of a rattle can clear. some base coat clear coat can't be put in a rattle can as a single stage
BAGGED89 is offline
post #6 of 45 (permalink) Old 02-16-2005, 01:56 PM
In my case it is not having access to a paint booth and/or air compressor system that will spray properly (i.e. nice and dry).
post #7 of 45 (permalink) Old 02-16-2005, 04:19 PM Thread Starter
ECU_Q's Avatar
Its not so much the money as it is the access to the right tools, and a booth. I just something where I can put her in the garage and then spray away.
ECU_Q is offline
post #8 of 45 (permalink) Old 02-16-2005, 04:27 PM Thread Starter
ECU_Q's Avatar
I couldnt get the best pictures because its only a camera phone, but thats pretty much whats going on. I would sand it down and then prime and then spray it down.
ECU_Q is offline
post #9 of 45 (permalink) Old 02-20-2005, 06:39 PM
Teal94BirdV8's Avatar
Send a message via AIM to Teal94BirdV8 Send a message via Yahoo to Teal94BirdV8
my enitire primer was done by rattle can.. lol.. i'm cheap..
94 LX V8 & 93 SC gone. Not forgotten.
1992 Lincoln Mark VII LSC Cobra U/L intake, PP 65mm TB, Powerdyne BD-11 8#, Walbro 255, FRPP 30lb Injectors, MSD ignition, 3.8 Taurus E-fan, A9P MAF conversion, Pypes 1&5/8" Shortys, O/R H-Pipe, 4.10 Trac-Lok, T-5 swap, FRPP flywheel, Ram HDX clutch, Steeda Clutch kit
2002 F150 FX4 Lariat 6" Fabtech, 3" BL, Stock FX4 wheels, 37x12.50 Nitto Trails, Yukon 4.56s, Detroit TrueTrac, Edge Evo, 8K HIDs, PowerStop truck&tow kit
1996 GMC Suburban SLT 6K HIDs, crystal clear light set, daily beater @ 222k miles
Teal94BirdV8 is offline
post #10 of 45 (permalink) Old 02-20-2005, 09:22 PM Thread Starter
ECU_Q's Avatar
Yea I had saw your car when I was on cardomain and again on rate my ride or something I think. How is it doing now, and how much did the Maaco job cost. Your car looks pretty good.
ECU_Q is offline
post #11 of 45 (permalink) Old 02-21-2005, 01:13 AM
Teal94TBirdV8, that does look pretty good. I've been wanting to do mine in primer black. I have a little bodywork to do though, so I'm going to price it at a local shop first.
loudpedal99 is offline
post #12 of 45 (permalink) Old 02-21-2005, 08:53 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
I didnt feel like buying a new bumper cover for the z26 before I sold it, so I fiberglassed the back side of the crack and bondoed the front. Dark grey primer and two different spray cans of color from autozone. You cant even tell until you look directly at that spot close range.
You can get a spray gun pretty cheap somewhere I'm sure. You could probably just get acrylic enamel single stage and spray it on pretty cheap. I used limco basecoat/clearcoat on my bird with spray gun and a homemade paint booth worked great except for the orange peel. Damn dirty spray gun
-Rob
-Rob
Rob is offline
post #13 of 45 (permalink) Old 02-23-2005, 08:21 PM
Audiobahnbird's Avatar
Send a message via AIM to Audiobahnbird
If you are planning on flat black out of a rattle can, plan on it looking like crap, its hard enough to make flat black look straight out of a gun......if you are going to do rattle cans do a light color and use a non fast drying paint, a paint that doesnt fast dry evens itself out if u overlap it, just like the real thing, but you get what is called hot spots with a fast drying paint, in other words, there will be lines where the paint dries, and it will be darker where it overlaps, no matter how thick u lay a fast dry on, its till gonna look like that....and dont try to do just a spot on a panel, if you need to fix a spot with a rattle can, its easiest to do the whole panel because feathering a rattle can paint into a 2 stage is nearly impossible.
Please enjoy my new and improved short signature- Russ
Audiobahnbird is offline
post #14 of 45 (permalink) Old 02-23-2005, 10:24 PM
ben_cline's Avatar
Hehe. Can't get a nice looking vehicle from a spray can?
I'm sure it took a lot of work, though.
http://duplicolor.com/projects/consu...P_mustang.html
http://duplicolor.com/projects/consu...cks/index.html
ben_cline is offline
post #15 of 45 (permalink) Old 02-24-2005, 08:29 AM
If your gonna use a rattle can buy the one stage stuff that has the clear mixed in with the paint (I think thats how its done, though someone else may know for sure) used this on my Ranger to fix a small rust spot on the A pillar. Looked good except the new paint obviously didnt have the fade of the factory stuff. Just lightly sand and polish it and you can get it to match good enought that unless you know where the paint is and look closely you wont notice. I just bought a can of touch up from Canadian Tire for it and it looked pretty good. Or if you want, go to an auto body supply store and they can make up a spray can with the factory color. Though you need to buy clear coat for this option. (And this way is alot more expensive, cost me 35 bucks for both for the Grand Marquis)
Blue LS is offline
post #16 of 45 (permalink) Old 02-24-2005, 08:34 AM
Anyone see this one: 91 SC!!
http://duplicolor.com/projects/consu...upercoupe.html
post #17 of 45 (permalink) Old 02-24-2005, 10:31 AM Thread Starter
ECU_Q's Avatar
Whoa, way to sunny in that SC for me. That looks like overkill. Where can I find a non fast drying paint, I live in sort of a small town so there isnt much by the way of auto body supply stores and what not.
ECU_Q is offline
post #18 of 45 (permalink) Old 02-24-2005, 01:33 PM
Rob
Rob's Avatar
LOL man now that dash in the SC is some ugly ****!!
-Rob
Rob is offline
post #19 of 45 (permalink) Old 02-24-2005, 03:57 PM
That SC belongs to someone over at sccoa. I think it's Alex LaChance's.
-Rod
post #20 of 45 (permalink) Old 02-24-2005, 07:32 PM
Looks alot like the local ricers that paint the interiors in strange colors.
Blue LS is offline
post #21 of 45 (permalink) Old 02-24-2005, 10:52 PM Thread Starter
ECU_Q's Avatar
Yea thats definitely a Honda Thundercivic. lol.
ECU_Q is offline
post #22 of 45 (permalink) Old 02-24-2005, 11:29 PM
I certainly can't disagee. I don't really understand why people do stuff like that.
-Rod
post #23 of 45 (permalink) Old 02-26-2005, 08:18 PM
True value....its called xorust, i did an entire jeep cherokee in it
post #24 of 45 (permalink) Old 02-26-2005, 09:14 PM
I was thinking of painting my interior Aluminum.... My car is Green, so it should match nicely
Anyone have a better color choice for my interior?
NiteFire is offline
post #25 of 45 (permalink) Old 02-26-2005, 09:18 PM
Hope its a good quality paint your gonna use. Every paint Ive seen that says "aluminum" or "chrome" looks like crap.
Blue LS is offline
post #26 of 45 (permalink) Old 02-26-2005, 10:41 PM
How bout painted to match the exterior?
97 Mark VIII LSC yeah
08 Ford Edge, white for now
modbird is offline
post #27 of 45 (permalink) Old 02-26-2005, 10:49 PM
how bout this:
Mirrachrome
Ghostchrome
I've sprayed this stuff, and its amazing, thats all I can say. hope the links work.
modbird is offline
post #28 of 45 (permalink) Old 02-26-2005, 10:55 PM
that is really really expensive... I could get a dash kit for that much
NiteFire is offline
post #29 of 45 (permalink) Old 02-26-2005, 11:01 PM
What kind of durability does that stuff have? I've used some of the cheap-o "chrome" paints, and they look great until they touch something harder than cotton, then they dull badly and just look like primer.
SloMo228 is offline
post #30 of 45 (permalink) Old 02-27-2005, 12:15 AM
$.25 poster
AlpineBird's Avatar
Send a message via AIM to AlpineBird
Whatever you do, DONT paint anything on your dash with "aluminum" paint, it does not work and looks horrible....i would be one to know.
Im glad i didnt ruin anymore dash peices with that stuff, i promptly bought a '97 console after that mistake and couldnt be happier with my plain black dash
'96 Alpine Bird 281ci
- Clear Corners
- DynoMax Cat-Back
- Purchased with 36,000 miles, now at 101k
- No mods planned untill it's DD life is over
1998 5.9 Limited Grand Cherokee
- Flowmaster Exhaust
- AEM Brute Force Intake
- Mopar Performance ECU
- 275hp-395ft/lbs at the crank (est.) Track results in the spring!!!
AlpineBird is offline
