Puddle Lights with a Spin - TCCoA Forums
post #1 of 13 (permalink) Old 02-19-2005, 02:58 AM Thread Starter
Raoul Duke
cougarcragar's Avatar
Thumbs up Puddle Lights with a Spin
Hey folks,
Some of you may have seen my thread in the past concerning Exploder/Mountaineer puddle lights. I wanted to fit them into the Cougar mirrors, but I didn't want to install Mark VIII mirrors either. As it turns out, our mirrors appear to be too shallow to install the lights. Also, the motor takes up most of the space within the mirror.
I decided to stick the lights under the car. Thanks to jk89cat, I got some late-'90s Exploder puddle lights and found a spot under the car to mount 'em
As you can see from the pictures, I used a cable tie to secure them to the transmission cross-member (is that what it is?). This is only temporary.
All connections on the wires were soldered, then coated with 3M liquid sealant.
The "hot" wire was traced through the firewall where it was connected into the floor lamp, therefore active with the illuminated entry system.
The pictures don't do the lights justice... it's a pretty slick effect.
All in all, I spent about four hours with the install, and everything went smoothly. If anybody has any ideas about a more secure method of mounting the lights, let me know. They are oddly shaped and cumbersome, so it will be difficult.
1996 Mercury Cougar XR7
cougarcragar is offline
post #2 of 13 (permalink) Old 02-19-2005, 08:41 AM
Awaiting E-Mail Confirmation
tinman_72's Avatar
Pretty slick. On my car, something like that wouldn't even make it up the driveway.
tinman_72 is offline
post #3 of 13 (permalink) Old 02-19-2005, 09:13 PM
That is a real good idea, but I'm with tinman_72. They wouldn't last an hour.
RAYBROADWAY is offline
post #4 of 13 (permalink) Old 02-20-2005, 05:26 PM Thread Starter
Raoul Duke
Thanks for the comments. They do seem to be pretty unsafe in their positions, but I did this same thing to my '88 XR7.
I got some cheapo utility lights from Auto Zone and set them up just like I did with these Exploder lights.
They were under the car for four years and never once got damaged. Plus, they were a lot bigger than these.
If something does happen to them, y'all will be the first to know.
post #5 of 13 (permalink) Old 02-20-2005, 05:36 PM
that is a sweet setup. Might consider doing that.
saint is offline
post #6 of 13 (permalink) Old 02-21-2005, 02:09 AM
Refrigerator Raider Hater
GreenBird's Avatar
I don't see it as useful unless it'll work with your keyless remote (No Tengo).
I'd like to see a lighted keyhole though.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #7 of 13 (permalink) Old 02-21-2005, 08:38 AM
My key hole lights up, did they change that in 96?
post #8 of 13 (permalink) Old 02-21-2005, 10:40 AM Thread Starter
Raoul Duke
It does work with the key fob. The lights are wired in with the floor lamps in the cabin, therefore they are active with the illuminated entry system.
These pictures really don't do the lights justice... it's a very cool effect.
My keyholes do not light up, which strikes me as odd. I mean, the keyholes on my '88 lit up!
post #9 of 13 (permalink) Old 02-21-2005, 10:43 AM
Took me over a year to realize my keyholes lit up. Have to pull up on the door handle to do it.
mastarecoil is offline
post #10 of 13 (permalink) Old 02-21-2005, 11:03 AM
Back in Black
ShadowDragon's Avatar
It was an option on all years.
ShadowDragon is offline
post #11 of 13 (permalink) Old 02-21-2005, 11:16 AM Thread Starter
Raoul Duke
Were illuminated keyholes a separate option from illuminated entry?
post #12 of 13 (permalink) Old 02-21-2005, 11:22 AM
$.25 poster
AlpineBird's Avatar
Send a message via AIM to AlpineBird
must have been, becuase i have illumited entry, but no illuminated keyholes.
'96 Alpine Bird 281ci
- Clear Corners
- DynoMax Cat-Back
- Purchased with 36,000 miles, now at 101k
- No mods planned untill it's DD life is over
1998 5.9 Limited Grand Cherokee
- Flowmaster Exhaust
- AEM Brute Force Intake
- Mopar Performance ECU
- 275hp-395ft/lbs at the crank (est.) Track results in the spring!!!
AlpineBird is offline
post #13 of 13 (permalink) Old 02-21-2005, 07:20 PM
I figured mine only did it when opened because I don't have remote lock/unlock.
