Shaker Hood?? - TCCoA Forums
post #1 of 17 (permalink) Old 02-22-2005, 10:42 PM Thread Starter
Shaker Hood??
Is it possible for Thunderbirds to have a shaker hood setup like that of Mach 1s?
EDIT: I just did a search, is there any regulars here that have it done?
1997T-Bird is offline
post #2 of 17 (permalink) Old 02-22-2005, 11:08 PM
I've never seen it on a Thunderbird. I don't think that it would be too difficult. I think that the shaker scoop just kinda bolts onto the intake manifold and then goes through the hood.
SloMo228 is offline
post #3 of 17 (permalink) Old 02-22-2005, 11:48 PM
Automatic Weapon
Big-Al's Avatar
1. Cut hole in hood
2. Bolt shaker intake on motor
3. Connect shaker intake to current MAF location.
4. Close hood
<----not throwing rocks at girls anymore
Big-Al is offline
post #4 of 17 (permalink) Old 02-23-2005, 12:44 AM
I put a post up awhile ago about doing this and I can spammed so bad about it.. I think it would be awesome!
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
post #5 of 17 (permalink) Old 02-23-2005, 01:13 PM
Back in Black
ShadowDragon's Avatar
1A) Get hood that would actually clear the intake
Originally Posted by Big-Al
1. Cut hole in hood
4. Close hood
ShadowDragon is offline
post #6 of 17 (permalink) Old 02-23-2005, 01:15 PM
Traveler's Avatar
Thats what I was thinking. I don't think the shaker fits on the standard NPI or PI intake. I could be wrong though.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #7 of 17 (permalink) Old 02-23-2005, 01:37 PM
i believe you would need a bullet intake.
tomaso12 is offline
post #8 of 17 (permalink) Old 02-23-2005, 02:23 PM
Automatic Weapon
Big-Al's Avatar
Why would you need a bullett intake? You do not want to run air directly from the outside stright into your motor. You need the MAF a certain distance from the TB. A MachI set up is really the same as the old Cobra, it just runs an air duct from the air filter to the "shaker" which sits on top of the motor.
Big-Al is offline
post #9 of 17 (permalink) Old 02-23-2005, 02:25 PM
Back in Black
I don't know about the Bullit intake. I do know the intake itself is too tall to clear a stock hood so you' have to cut out more than just the shaker or get a cowl hood.
post #10 of 17 (permalink) Old 02-23-2005, 02:29 PM
JustinH's Avatar
the bullit intake fits just fine under a stock hood, just gotta cut up the supports a bit.
JustinH is offline
post #11 of 17 (permalink) Old 02-23-2005, 03:34 PM Thread Starter
So you just got to cut a hole in the hood pretty much that will fit the shaker and all done?
post #12 of 17 (permalink) Old 02-23-2005, 04:09 PM
Back in Black
And the rest of the intake that will stick above a stock hood...
post #13 of 17 (permalink) Old 02-23-2005, 04:23 PM
motor city poster
Red96Bird's Avatar
the mach ones use the stock xx-99-xx year cobra intake manifold, i know this because my friend has a 99 cobra motor, and my boss has a 03 mach 1 and they are the same upper intake manifolds
the mach just doesnt have the shiny silver coating and no snake
Red96Bird is offline
post #14 of 17 (permalink) Old 02-23-2005, 06:56 PM
Sweet T
SanDiegoLXBird's Avatar
I don't remember who.. but there is somebody out there selling a shaker kit for GT Mustangs. It'd probably fit the TBird okay. Again.. the problem would be hood clearance for all the crap that's supposed to be under the hood.
SanDiegoLXBird is offline
post #15 of 17 (permalink) Old 02-23-2005, 07:00 PM
Back in Black
http://www.mustangtuning.com/ramairshscsy1.html
http://www.partshopper.com/fordmusta...DC-105115.html
Quick search on Google
post #16 of 17 (permalink) Old 02-23-2005, 08:19 PM
Automatic Weapon
Big-Al's Avatar
Almost 800.00 for a shaker set up that doesn't even shake!
Big-Al is offline
post #17 of 17 (permalink) Old 02-23-2005, 08:23 PM
Resident Gun Guru
SHADOW's Avatar
Since the day I saw this Shaker kit install on a 2000+, (unsure of the year), Mustang on Horse Power TV, I have thought this would be a great addition to my 97. Looks like it would just require minor modification to mount it in the T-Bird, the harder part would be hooking the air intake up properly, but I think the kit is plenty adaptable.................but it is a little pricey.........definately something I'd like to explore in the future........
13.66 @ 100.4 mph
1.94 60' time
"If you stick with the basics, you never have to go back to them"
SHADOW is offline
