Sagging Doors - TCCoA Forums
post #1 of 6 (permalink) Old 02-24-2005, 09:43 PM Thread Starter
Sagging Doors
Has anyone else had the problem with their doors sagging, i think that my lower door hinge is dead but before i went and forked out $30 a door for the hinges i would rather try to fix it a Free way being that i am a poor student and all. I wanted to know if anyone else has had this problem and if so how did they fix it?
burittobob is offline
post #2 of 6 (permalink) Old 02-24-2005, 10:41 PM
This problem has plagued almost all MN12 owners, and mine is starting up as well. Unfortunately, I don't think there's a "FREE" solution, but I could be wrong.
Rally is offline
post #3 of 6 (permalink) Old 02-24-2005, 10:44 PM
Traveler's Avatar
Body shop installed new pins and bushings in the hinges of my passenger door for about 50.00 per side. I thought it was a great deal.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 6 (permalink) Old 02-25-2005, 01:32 AM
Hinge Threads.
Ton's O Info. It's not difficult. Get your hands a little dirty.
soop is offline
post #5 of 6 (permalink) Old 02-25-2005, 04:29 PM
Haha, I cheaped out and put a washer between the door and the hinge on the lowest bolt on the bottom hinge. I just jacked up the door a little (wood in place) and loosened the top bolt of the bottom hinge and removed the bottom bolt in order to squeeze a washer in there. Reinstalled the bottom bolt and tightened both bolts. No more sag, door closes with a nice light push.
Unherd is offline
post #6 of 6 (permalink) Old 02-25-2005, 04:40 PM
yup, i need to do that to my driver door, its sagging like woo
2007 mazda 5- grocery getter
95 mustang gt convertible- newest project
thunderchicken17 is offline
