Plastic/rubber strips to line the bottom edge of doors? - TCCoA Forums
post #1 of 7 (permalink) Old 03-08-2005, 03:25 PM Thread Starter
Hey all,
One of the most unsightly things about my 'Bird is the fact that the very bottom edge of my passenger-side door is rusted, all the way from front to back. I did try grinding it and repainting it, but it rusted the paint off again in a matter of days. It doesn't go very far up the door however, maybe only 1/2 an inch at most. So I was wondering --
Do they sell any kind of strip, plastic or otherwise, that I could attach to run along the bottom edge of the doors? Yes it's just a way to cover it up, and that's the goal. I envision something like the rubber liner, where you push it up onto the door edge bit by bit. But nothing that will interfere with the door closing.
If not, know of any other good ways to cover the bottom edge (and the rust) that will last for awhile?
Thanks!
EdwardNorth is offline
post #2 of 7 (permalink) Old 03-08-2005, 07:08 PM
use tape and newspaper to mask off the area you want covered. get some black rockerguard or rubberized undercoating, either or. aresols avaliable at the parts store. scuff the area with a kitchen scotchbrite and wipe clean. spray on and use light coats, letting each dry a bit or itll run. rust wont eat through for a while, and when it does, squirt, done.
this tip also works well to hide duct tape repairs. good for inspection around here.
97 Mark VIII LSC yeah
08 Ford Edge, white for now
modbird is offline
post #3 of 7 (permalink) Old 03-08-2005, 10:06 PM
LMAO rusted through in days? My right side rocker had some bubbling and pits. I grinded that sucker down, bondo, sand, bondo, sand, painted and have had a prob.
I remember in the EASTWOOD catalog that they had paint that you could put OVER rust (not the loose parts) and it would actually stop the rust from being bigger. Then u just paint over that ur car color and not worry about it.
ITHURTZ is offline
post #4 of 7 (permalink) Old 03-08-2005, 11:06 PM
Who is John Galt?
i've heard good things about POR 15 (I think that's what it is). My uncle used it on his Vette when he restored it.
"Won't work, can't be done"
cougar_guy04 is offline
post #5 of 7 (permalink) Old 03-08-2005, 11:56 PM Thread Starter
Thanks for the replies, I'll definately look into these things.
post #6 of 7 (permalink) Old 03-10-2005, 05:11 PM
ya POR15's good stuff
IIRC pretty pricey too
Jimbo is offline
post #7 of 7 (permalink) Old 03-10-2005, 05:33 PM
http://www.por15.com/
just incase
ITHURTZ is offline
