left brake lamp not working - TCCoA Forums
post #1 of 2 (permalink) Old 03-29-2005, 08:50 AM Thread Starter
gavinl's Avatar
I have a gremlin in my left brake lamp. Both lamps work with the hazard/signals and the 3rd & right brake lamps comes on when braking except for the left one.
So if the left signal lamp works, means bulbs ok.....which switch or relay should I be looking at for one brake lamp to not work?
gavinl is offline
post #2 of 2 (permalink) Old 03-29-2005, 10:19 AM
Try swapping the bulb to the side that works and see if the problem follows it. You may just have a bad filament in the bulb. I think these bulbs are multi-filament style. If so, then just replace the bulb.
Jay
FordMan77 is offline
