Turn signals - TCCoA Forums
post #1 of 6 (permalink) Old 04-04-2005, 12:20 PM Thread Starter
Turn signals
ok i was wondering my turn signals have not been working i think the flahser might have gone out. I have looked at the fusebox, that is useually where they are located. An I did look at the fuse its self and it wasn't blow can anybody help me
thanks
Justin
P.S when i bought the car the fourways never worked, but the regular turn signals did.
96TBirdMan is offline
post #2 of 6 (permalink) Old 04-04-2005, 02:17 PM
Resident redneck
redneckcougarguy's Avatar
Send a message via AIM to redneckcougarguy Send a message via MSN to redneckcougarguy
have you tried replacing the bulbs?
-Steven
Project Rust Prevention: 1990 Buick Regal, Toilet Capacity engine, new trim paint, 57K miles
redneckcougarguy is offline
post #3 of 6 (permalink) Old 04-04-2005, 02:31 PM
Trumpeter Extraordinaire
IronChopz's Avatar
Some info from the 1996 Service Manual - it could be a faulty flasher module, which is located in the fuse panel:
PINPOINT TEST DA: TURN SIGNAL LAMPS/HAZARD FLASHER LAMPS INOPERATIVE
DA1 CHECK INDICATOR FLASHER GROUND
Using an ohmmeter connected to a known good ground, connect second lead to Circuit 57 (BK) at indicator flasher.
Measure resistance.
Is resistance 5 ohms or less?
Yes
GO to DA2.
No
SERVICE Circuit 57 (BK) for open circuit. RESTORE vehicle. RETEST system.
DA2 CHECK CIRCUIT 44 (LB)
Disconnect indicator flasher.
Connect one lead of an ohmmeter to Circuit 44 (LB) at flasher connector, connect second lead to Circuit 44 (LB) at Pin C2-6 of multi-function switch.
Measure resistance.
Yes
RECONNECT indicator flasher. GO to DA3.
No
SERVICE Circuit 44 (LB) for open circuit. RESTORE vehicle. RETEST system.
DA3 CHECK CIRCUIT 44 (LB) FOR VOLTAGE
Turn ignition switch to RUN.
Using a voltmeter connected to a known good ground, check Pin C2-6, Circuit 44 (LB) of multi-function switch for voltage.
Is B+ present?
Yes
GO to DA4.
No
GO to DA5.
DA4 CHECK CIRCUIT 3 (LG/W) OUTPUT
Actuate multi-function switch to the left turn position.
Using a voltmeter connected to a known good ground, connect other end to Pin C2-8, Circuit 3 (LG/W) at multi-function switch.
Is B+ present?
Yes
REPLACE indicator flasher. RESTORE vehicle. RETEST system.
No
REPLACE damaged multi-function switch. RESTORE vehicle. RETEST system.
DA5 CHECK SUPPLY TO INDICATOR FLASHER
Gain access to indicator flasher.
Using a voltmeter connected to a known good ground, check Circuit 383 (R/W) for B+.
Is B+ present?
Yes
GO to DA7.
No
GO to DA6.
DA6 CHECK CIRCUIT 10 (LG/R) FOR SHORT
Using an ohmmeter connected to ground, connect second lead to output side of STOP/HAZ fuse (15A) cavity.
Measure resistance.
Yes
SERVICE Circuit 10 (LG/R) for short to ground. RESTORE vehicle. RETEST system.
No
REPLACE damaged STOP/HAZ (15A) fuse. RESTORE vehicle. RETEST system.
DA7 CHECK CIRCUIT 57 (BK)
Measure resistance.
Yes
GO to DA8.
No
DA8 CHECK CIRCUIT 385 (W/R)
Connect one lead of an ohmmeter to Circuit 385 (W/R) at flasher connector, connect second lead to Circuit 385 (W/R) at Pin C2-11 of multi-function switch.
Measure resistance.
Yes
RECONNECT indicator flasher. GO to DA9.
No
SERVICE Circuit 385 (W/R) for open circuit. RESTORE vehicle. RETEST system.
DA9 CHECK INDICATOR FLASHER OUTPUT
Using a voltmeter connected to a known good ground, check Pin C2-11, Circuit 385 (W/R) of multi-function switch for B+.
Is B+ present?
Yes
GO to DA10.
No
REPLACE damaged indicator flasher. RESTORE vehicle. RETEST system.
DA10 CHECK MULTI-FUNCTION SWITCH OUTPUT
Actuate multi-function switch to the HAZARD FLASHER position.
Is B+ present?
Yes
No
Indicator Flasher
Removal and Installation
1. Disconnect battery ground cable (14301). Refer to Section 14-01.
2. Access indicator flasher (13350) in the fuse junction panel (14A067).
3. Pull indicator flasher straight away from fuse junction panel.
4. To install, align indicator flasher with fuse junction panel and push into place.
Also:
Indicator Flasher
An electronic indicator flasher (13350) (warning flasher) is retained by a bracket to the lower LH instrument panel reinforcement (04545).
1. Remove screw retaining indicator flasher to lower LH instrument panel reinforcement.
2. Unplug indicator flasher from electrical connector and remove from vehicle.
3. To install, reverse Removal procedure.
Indicator Flasher
IronChopz is offline
post #4 of 6 (permalink) Old 04-04-2005, 02:57 PM
Raoul Duke
cougarcragar's Avatar
I'll bet dollars to donuts that the multi-function switch needs to be cleaned or replaced.
If you move the lever and the signal doesn't come on, try fiddling with the hazard/flasher button on the column.
I took mine apart and cleaned the contacts. Now it works fine.
1996 Mercury Cougar XR7
cougarcragar is offline
post #5 of 6 (permalink) Old 04-04-2005, 03:13 PM
Jedi Master
mn12xr7's Avatar
-Orlando
mn12xr7 is offline
post #6 of 6 (permalink) Old 04-04-2005, 10:59 PM Thread Starter
thanks cougarcrager that is the problem. She is workin now but thanks to all you guys for the input
