broken moonroof - TCCoA Forums
post #1 of 3 (permalink) Old 05-06-2005, 01:44 AM Thread Starter
broken moonroof
so i was going a little fast and the suction popped my moonroof open into the sunroof position. now if i do 75+ there is a whisling noise from it. also if i press the button to make it go to sunroof mode it sticks halfway and i have to push on it till it makes a popping noise and goes up another inch or so... iv tried to look at this to fix it but... lack of space and lack of know how prevents me from doing anything. any ideas?
95-5spd-sc is offline
post #2 of 3 (permalink) Old 05-06-2005, 08:28 AM
Trumpeter Extraordinaire
IronChopz's Avatar
If the glass panel doesn't open properly, it's possible the motor's out of sync, or there are obstructions in the path.
Check this thread (post #5) for some diagnostics info.
Whistling noise is probably due to incorrect sealing. Glass panel is supposed to fit snuggly when closed. Make sure the seal is tight.
Perform a search here as well. Other info has been posted in the past.
IronChopz is offline
post #3 of 3 (permalink) Old 05-07-2005, 05:02 PM
i think i have the same problem as u....the rubber sealant came off the glass right? well thats what happened to me...its only in one corner though so all i ahve to do is push the opposite corner down and itll open
Statik is offline
