please someone help me on the doors...im a newbie! - TCCoA Forums
post #1 of 5 (permalink) Old 05-18-2005, 07:57 PM Thread Starter
Wink please someone help me on the doors...im a newbie!
hi all,
i bought a 95 t-bird...its pretty nice,but the drivers door is hanging alittle......is it hard to make it easy to close again?...i had the same problem in my 93 mustang but i got rid of it before i could fix the door.......any help appreciated!
1974 fiat x19
1982 datsun 280zx turbo
1967 mustang fastback
1973 mustang mach 1 q code
angf117 is offline
post #2 of 5 (permalink) Old 05-18-2005, 07:57 PM Thread Starter
im pretty sure its a bushing or something like that
1974 fiat x19
angf117 is offline
post #3 of 5 (permalink) Old 05-18-2005, 08:20 PM
motor city poster
Red96Bird's Avatar
most likely the lower hinge has to be replaced, i did it myself wiht some help of friends, but its kinda a pain in the butt, i replaced the lower hinge, couldnt get the door aligned, took it to the dealership, paid them to do it and at the same time replace the uppper hinge because that was bad too.
now its time to fix the passenger door..
Red96Bird is offline
post #4 of 5 (permalink) Old 05-19-2005, 09:30 AM
girdnerg's Avatar
I just fixed mine with the kit at www.mn12performance.com. He has instructions with pics in the page with the info on it. Just follow the links for the repair kit.
Hope that helps,
Rob
girdnerg is offline
post #5 of 5 (permalink) Old 05-19-2005, 09:44 AM
Traveler's Avatar
That should be just what you need, and a lot cheaper than having a dealer doing it!
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
