Trunk key hole - TCCoA Forums
post #1 of 3 (permalink) Old 10-28-2002, 10:29 AM Thread Starter
5w30 Guzzler
chilipepprflea's Avatar
Send a message via AIM to chilipepprflea
Trunk key hole
did they make a trunk keyhole that was visible from being behind the car (about the same level as the blue oval, but in the middle) on EVERY 94 LX? the reason i ask is, when i bought my car used, the owner said the previous owner had taken the trunk lock out so no one could get into the trunk and steal his system. all i could see was that on the underside of the trunk (where it curves under) right above the license plate, there is a slit that if you sprayed water in it, it would get directly into the trunk (car wash has done it a little). just wanted to know if the guy had the lock shaved.
thanks
rob
chilipepprflea is offline
post #2 of 3 (permalink) Old 10-28-2002, 10:54 AM
Refrigerator Raider Hater
GreenBird's Avatar
yes. every thunderbird came with a trunk lock
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #3 of 3 (permalink) Old 10-28-2002, 11:16 AM Thread Starter
5w30 Guzzler
thanks greenie
sorry i just got done watching the frank grimes episode of the simpsons.
rob
