Hood Pins - TCCoA Forums
post #1 of 12 (permalink) Old 10-28-2002, 03:24 PM Thread Starter
17Mark71's Avatar
Hood Pins
Where's a good location to mount hood pins on a 97 Bird? Anyone got pictures?
'97 Sport Option'd T-Bird
DSS Shortblock, PI Heads, 262AH Cams, Kooks, SVO SC with stock pulley,
42 lb injectors, 70mm TB, '02 GT MAF, Vogtland Springs, Mk VIII DS,
Marauder TC, 17" SVT T-Bird Rims, Michelin PS2 235/50/17, True Duals,
4.10 gears, J-modded tranny
300RWHP 335RWTQ
Member of www.midwestthundercats.com
17Mark71 is offline
post #2 of 12 (permalink) Old 10-29-2002, 08:22 AM
I am at work right now but I will take some pics tonight.
danman
danman is offline
post #3 of 12 (permalink) Old 10-31-2002, 12:41 PM
CamellionCat's Avatar
Send a message via AIM to CamellionCat
heres a good picture of hood pines.
These are hood pines from discount auto parts.
Marvin M.
95- Cougar- SOLD (in loving memory)
Mods-17x9 cobra r's,H&R springs,KYB shocks & struts,removed air silencer,9"K&N cone,gutted cats,dual glasspack setup,cooling fan switch, B&M 24,000 tranny cooler.
Back in the game!!!
97 Lincoln Mark VIII LSC-opal opalescent with black interior, upgraded with a 98 tranny, 18x9 black saleen speedstars, LMS dual tip mufflers, 5% tints all around.
CamellionCat is offline
post #4 of 12 (permalink) Old 10-31-2002, 01:23 PM Thread Starter
17Mark71's Avatar
Where did you secure the posts too under the hood?
300RWHP 335RWTQ
17Mark71 is offline
post #5 of 12 (permalink) Old 10-31-2002, 01:27 PM
Back in Black
ShadowDragon's Avatar
A good place to secure them would be instead of the rubber stoppers.. John Jackson has done it this way.
ShadowDragon is offline
post #6 of 12 (permalink) Old 10-31-2002, 02:24 PM
Cougar Pilot
BlackCat94's Avatar
If you put hood pins on a car can you get rid of the factory hood latch?
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
post #7 of 12 (permalink) Old 10-31-2002, 02:27 PM
Back in Black
Yah, they will hold the hood down instead of the latch.
post #8 of 12 (permalink) Old 10-31-2002, 09:27 PM Thread Starter
17Mark71's Avatar
Re-word
I guess I should be a little more clear. Where should I mount the posts? Pictures would be helpful. I think Danman is still working that.
300RWHP 335RWTQ
17Mark71 is offline
post #9 of 12 (permalink) Old 10-31-2002, 10:06 PM
Back in Black
That's what I meant, sorry.
Under the hood there is two rubber feet that screw up and down so you can adjust the height of the hood.
You can take those out and mount the pins there. No holes to drill (in the frame) and it's a rather sturdy place.
post #10 of 12 (permalink) Old 10-31-2002, 11:45 PM
I cut a small hole in the frame rail that is right next to the post that holds the hood in place. I will take some pics. Sorry, but tonight just turned out to be a bad night. I will take some pics tomarrow evening after work.
danman
danman is offline
post #11 of 12 (permalink) Old 11-01-2002, 09:13 AM
Homer's Avatar
EDIT
Hoosier Daddy
Homer is offline
post #12 of 12 (permalink) Old 11-01-2002, 10:54 AM Thread Starter
17Mark71's Avatar
Danman, SD and Homer,
Thanks for the info on this.
Danman, If you don't get he pictures in soon that's OK. I probably won't mount them until next Spring anyways. So no hurry.
Thanks again,
Mark
300RWHP 335RWTQ
17Mark71 is offline
