Mounting SC GFX?? - TCCoA Forums
post #1 of 3 (permalink) Old 11-04-2002, 09:02 PM Thread Starter
Send a message via AIM to ruffledfeathers
Mounting SC GFX??
I know it has been asked b4.
I think i figured out how to mount the bottom peices
But the peices on the door have me stumped.
How is the best and esiest way to mount the door things?
I have alot of 3m two sided tape if that helps.
94 LX 4.6
SC GFX , Suspension Techniques springs bilstein struts
R.P.C. tuning, 80mm mMAF
2 steps colder plugs, 9 mm wires 180 stat1 piece alum. driveshaft, 3.73 gears
2.5 inch Xpipe no 3rd cat , no mufflers
PI Stallion 9 inch 3k stall converter
March underdrive pullies
Zex dry Nitrous kit 75 hp for now
[email protected] with no traction !SOLD!
93 mustang notch 5.0
ruffledfeathers is offline
post #2 of 3 (permalink) Old 11-05-2002, 03:11 PM
Do you have the mounting hardware for the doors? I have never tried this, but I would think if you riveted the mounting hardware onto the door and snapped the gfx piece over them, it would probably the best way to do it.
LZ1276 is offline
post #3 of 3 (permalink) Old 11-05-2002, 06:40 PM
Kevin's Avatar
Send a message via AIM to Kevin
I have just pulled the door pieces off a SC a few weeks ago, so the info is still fresh in my mind:
There are about 6-8 plastic pieces that hold/support the metal trim piece on the door, and each of those plastic pieces is slid over a metal protrusion. Simply pop riviting these pieces to the door will work - and that's how I'll be doing it.
Each door trim piece also has 2 'bolts', one on each end, they go through holes in the door, and are 'nutted' on the other side.
How do you plan on mounting the plastic pieces for the sides? I ask this cause I could always use a new suggestion .
1992 Mercury Cougar XR7 5.0 - Rust In Pieces
1995 Mercury Cougar XR7, rust free Florida car - future 5.0 project
Kevin is offline
