Removing the Bird emblem....recommended? - TCCoA Forums
post #1 of 16 (permalink) Old 11-30-2005, 07:30 PM Thread Starter
ortbird's Avatar
Exclamation Removing the Bird emblem....recommended?
I guess I'm bored after all the finals at school...
I'm thinking more and more about removing the Tbird emblem from the front grille, or painting it black...
finally found this Photo of a 96/97 bird without the bird emblem here on member's rides:
http://www.tccoa.com/rides/warpat.shtml
I want to know what you guys think...I can't decide if it looks good or not.
and bear in mind, my car is a light denim blue, not black...
anyway. let me pls know aht you guys think. If any of you have done it, let me see pics...
and btw, Will it be difficult to remove from the frille?
Thanks a lot.
ortbird is offline
post #2 of 16 (permalink) Old 11-30-2005, 07:43 PM
dwinthrup's Avatar
i would leave it but it's your car if you take it off you can always put it back it you don't like it
dwinthrup is offline
post #3 of 16 (permalink) Old 11-30-2005, 07:57 PM
thunderbird96's Avatar
Send a message via AIM to thunderbird96 Send a message via MSN to thunderbird96 Send a message via Yahoo to thunderbird96
just rembember this you have to take the bumper off .I changed mine to mesh with a 4.6 logo when i painted my car. the corner lamps need to come off then the screws in the wheel wells then underneath the car there are bolts that bolt the bumper to the fender. and the plastic air dam underneath has to be remove then the cover can come off.
thunderbird96 is offline
post #4 of 16 (permalink) Old 11-30-2005, 08:00 PM
i had to because i could not get my huge hands down there to do it . you cna try going in from the top but hood latch needs to be removed i don't have one but i couldn't reach the screw because of the bumper reinforcment plastic piece the bumper slides over
post #5 of 16 (permalink) Old 12-01-2005, 09:59 PM
Earl's Avatar
Personally, I don't think removing the bird from the front of the car does anything positive to it...especially on a 96-97....that was like the main focal point of the front end....that huge-*** bird in the front of the car! it's freakin' cool....hell, I have a tatoo of that huge *** bird So I guess you could say that I like it and I would leave it...What would be REALLY COOL would be no grill, and a floating bird emblem
Earl is offline
post #6 of 16 (permalink) Old 12-01-2005, 10:13 PM
Let's see it...
Grasshopper is offline
post #7 of 16 (permalink) Old 12-01-2005, 11:46 PM
jesusraybrown's Avatar
Be different. Take it out.
1. This forum requires that you wait 30 seconds between sending private messages. Please try again in 266079416 seconds. wtf?
jesusraybrown is offline
post #8 of 16 (permalink) Old 12-02-2005, 01:27 AM
Earl's Avatar
Originally Posted by Grasshopper
Let's see it...
I'll have somebody take a pic of it....I'm getting a running horse (mustang) next to it as soon as I have an extra bit of money to blow
Earl is offline
post #9 of 16 (permalink) Old 12-02-2005, 07:44 AM
Toombs's Avatar
Well, here's a couple of pics of it removed on a car closer to your color. Keep in mind that mine's actually a 94 Cougar with a nose job, but you get the idea. Also, the honeycomb grill is solid behind the bird, so even if you take the bird off, it won't stand out, but you'll still have a bird image in the middle. You can really see this in the second pic.
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- DirtyDog Converter (3,800)
- SCT Micro Tuner from Blue Oval Chips
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #10 of 16 (permalink) Old 12-02-2005, 08:22 AM
Carlover007's Avatar
I like the painted look...
Carlover007 is offline
post #11 of 16 (permalink) Old 12-02-2005, 10:28 AM
thunderbirdlver's Avatar
Send a message via AIM to thunderbirdlver Send a message via Yahoo to thunderbirdlver
man the bird is a symbol of a great car. and an american icon that i have everywhere. my brother has it on his arm too. i thought about it but im not sure. its ur car but removing it makes like every honda out there.
If your exhaust tip is larger than your cylinder bore, then you are a Ricer.
thunderbirdlver is offline
post #12 of 16 (permalink) Old 12-02-2005, 10:52 AM
Ainline41's Avatar
Send a message via AIM to Ainline41
one of my friends gave me a 9 inch neon tube which i put behind the front grill, i think it looks pretty good, although with just one light on the car its kinda weird, dont have any pics does sound a little like a ricer but oh well i barely ever have it on
Ainline41 is offline
post #13 of 16 (permalink) Old 12-02-2005, 03:17 PM
that would b cool to have the bird emblem in the front then at night it lit up indiglo.
post #14 of 16 (permalink) Old 12-02-2005, 03:47 PM
well mine is at streetsourcemag.com my screen name is mys10slams. i have mesh with a 4.6 logo in the grill
post #15 of 16 (permalink) Old 12-05-2005, 01:40 AM
SVT2888's Avatar
Send a message via AIM to SVT2888
Mods: Concrete Median
CNCpics.com-Automotive Event Photography
Facebook
Ebay Store
Official B-team member. Viva La Revolucion!
SVT2888 is offline
post #16 of 16 (permalink) Old 12-05-2005, 01:47 AM
SVT2888's Avatar
It has a bird now though and IMO it looks better with it. I got it without a grill because it's an SVT (Salvage Vehicle Title ). There is no foam behind the bumper cover either, so removing the grille is very easy.
Facebook
Ebay Store
SVT2888 is offline
