Brake light problem.. need help - TCCoA Forums
post #1 of 2 (permalink) Old 12-01-2005, 11:19 PM Thread Starter
I've a brake light problem on my '93 5.0 tbird. It's located on the left rear side. The light will go off when the road is not smooth, such as holes, bump. But, if I make a left turn signal, the light works when I brake. There are no problems on the right rear side & high-mounted brakelamp. I really appreciate any help on this. Thanx
tbirrrd is offline
post #2 of 2 (permalink) Old 12-01-2005, 11:54 PM
The Great Obucina's Avatar
check the harness plug behind the carpeting near the fuel interia switch and check the harness at the bulb.
"Booyah". Stu Scott.
The Great Obucina is offline
