spoiler mounting - TCCoA Forums
post #1 of 8 (permalink) Old 12-14-2005, 08:46 PM Thread Starter
chris g's Avatar
Send a message via Yahoo to chris g
Question spoiler mounting
what would be the best way to mount a spoiler?
i was thinkin 3m double sided tape.
COLD AIR INTAKE, MN12 PERFORMANCE FRONT SUSPENSION KIT, SILVER PAINTED AVS WINDOW GUARDS, SILVER PAINTED DASH PANELS, 28% MIRROR TINTED WINDOWS, SUSPENSION TECHNIQUES 2'' DROP, TRUE BENDS CUSTOM 2.5'' TRUE DUAL EXHAUST. 2nd generation SC wheels.
chris g is offline
post #2 of 8 (permalink) Old 12-14-2005, 09:42 PM
Traveler's Avatar
I wouldn't trust it to tape. Only way I'd trust is to bolt it on. Though I'd have to hire someone to do it and not watch them drill the holes!
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #3 of 8 (permalink) Old 12-14-2005, 10:15 PM
jk69cat's Avatar
yea its ugly, with the ford one with the template, 5 smaller holes, 1 9/16 hole and then the hole saw to the back of the trunklid to make sure you can attach it .
mn12 less!
jk69cat is offline
post #4 of 8 (permalink) Old 12-16-2005, 06:27 PM
I wouldn't trust just tape either. Mount it with some bolts and tape.
My spoiler had two bolts broken off each side, so I put to drywall mounting bolts in their place. Like a charm, 3 years and running.
RAYBROADWAY is offline
post #5 of 8 (permalink) Old 12-21-2005, 03:02 PM
Desert Rat's Avatar
Does the 96-97 spoiler mount to a 95 decklid? Kinda like the way they look.
Desert Rat is offline
post #6 of 8 (permalink) Old 12-21-2005, 03:10 PM
I don't know how that one mounts but if you drill remmember to paint the holes so they don't rust then use some sort of rubber O ring so no watter gets in the trunk. you may think I'm stupid for reminding you to do this but I have seen it not done right so 1000s of times and it is so easy to do it right.
aceospades is offline
post #7 of 8 (permalink) Old 12-21-2005, 03:41 PM
Desert Rat's Avatar
Don't have much of a rust problem here in Arizona, but good advice nonetheless.
post #8 of 8 (permalink) Old 12-21-2005, 04:13 PM
Traveler's Avatar
Yes, all of the mn12 trunklids are pretty much the same.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
