Condensation in corner lights... - TCCoA Forums
post #1 of 5 (permalink) Old 01-16-2006, 12:06 PM Thread Starter
MAMN12 Posse Member
JeffTBird93's Avatar
Is there any way to keep this from happening. This is my second set of clear corners, and both times, I've gotten condensation in my driver side one which eventually makes them look like crap. Is there any way to clear these things up or keep it from happening? Thanks.
~Jeff
*signed off
JeffTBird93 is offline
post #2 of 5 (permalink) Old 01-16-2006, 12:32 PM
I'm with you man, I keep getting condensation in my corners and yeah, looks nasty.
95XR7 is offline
post #3 of 5 (permalink) Old 01-16-2006, 01:12 PM
Raoul Duke
cougarcragar's Avatar
Remove them and let them sit inside for 24 hours or so. This will dry them out.
Once you do this, run a bead of outdoor silicone sealant, then press the bead into the joint with your finger.
This has worked for me in the past.
1996 Mercury Cougar XR7
cougarcragar is offline
post #4 of 5 (permalink) Old 01-16-2006, 01:33 PM
I've had mine for like 3 or 4 years and I'm fine never had a problem.
aceospades is offline
post #5 of 5 (permalink) Old 01-16-2006, 02:41 PM Thread Starter
MAMN12 Posse Member
Yeah, I had a set of 89-95 ones that I had for a few years and didn't have a problem with, but since I swapped my headlights, I can't get them to stop. I'll try that cougar.
~Jeff
*signed off
