Night Shades Removal - TCCoA Forums
post #1 of 5 (permalink) Old 01-29-2006, 12:09 AM Thread Starter
Resident Line Creator
th3subtl3on3's Avatar
After install the LED strips in the rear lights, I would like to show them off a bit more. To do this, I want to remove the Night Shades that I put on the rear lights. There is nothing stated on the can as to how to remove it. Anyone know how to remove it without damaging the lights? Thanks.
-Brian
th3subtl3on3 is offline
post #2 of 5 (permalink) Old 01-29-2006, 12:16 AM
Who is John Galt?
I had to reshoot my first coat. I stripped it off with Acetone. Didn't melt the lights housing.
"Won't work, can't be done"
cougar_guy04 is offline
post #3 of 5 (permalink) Old 01-29-2006, 12:21 AM Thread Starter
The acetone did not affect the plastic at all? Heres some information I found, maybe off their website?
How do I remove VHT Nite Shades SP-999 Lens Tint?
Usually a little lacquer thinner on a clean lint free cloth will take it off. If the tint is more than 3 months old, it may be baked into the surface and normally will not come off.
-Brian
post #4 of 5 (permalink) Old 01-29-2006, 10:48 PM Thread Starter
I guess if nothing works, I can just turn to sanding. Start with 400 and work my way to about 1500, then start wet sanding. Once its all removed, just buff it real nice with some type of compound. Then clear coat it or something along those lines.
-Brian
post #5 of 5 (permalink) Old 01-29-2006, 11:21 PM
tyman00's Avatar
I personally would avoid laquer on plastic. Try mineral spirits or acetone. That is what I would try. Like you said, worst comes to worst you get to spend the better part of an afternoon sanding and polishing.
tyman00 is offline
