what's needed to swap over gas tanks? - TCCoA Forums
post #1 of 6 (permalink) Old 01-29-2006, 11:39 AM Thread Starter
Jedi Master
mn12xr7's Avatar
as you can see <--- i own a 91, but i wanted to do some other things with my exhaust, like actually put a rear exit, what's needed to do this swap??? i've searched a bit but found no real answer. thanx in advance.
-Orlando
mn12xr7 is offline
post #2 of 6 (permalink) Old 01-29-2006, 11:46 AM
The Great Obucina's Avatar
besides, the tank...I would have to say the mounting straps. i cant imagine ford would have actually spent the money to retool the inlet and outlet tubing on the passenger side fenderwell, i would grab all the necessary hoses and lines from the tubing at the fenderwell to the tank also.
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 6 (permalink) Old 01-29-2006, 03:45 PM
jk69cat's Avatar
all you need is the tank, exhaust and pump, the straps should be the same . and the fuel lines and filler hoses/vent are the same
mn12 less!
jk69cat is offline
post #4 of 6 (permalink) Old 02-26-2006, 11:01 AM Thread Starter
Jedi Master
mn12xr7's Avatar
do you about how much i'll end up spending???
-Orlando
mn12xr7 is offline
post #5 of 6 (permalink) Old 02-26-2006, 12:57 PM
jk69cat's Avatar
that depends on what you find
mn12 less!
jk69cat is offline
post #6 of 6 (permalink) Old 02-26-2006, 02:07 PM
Full Metal
RedThunder94's Avatar
if you go junkyard, the tank will prolly be about a 50-100, pick and pull sucks 'cause they punch holes in everything to drain the fluids, so it's hard to find one there, i woud say highball it and say 200 bux for everything..
2004 Mercury Grand Marquis GS
1999 VW New Beetle SOLD!
click here to check 'em out.
RedThunder94 is offline
