replacing sunroof gasket - TCCoA Forums
post #1 of 10 (permalink) Old 02-01-2006, 04:08 PM Thread Starter
ThunderONWheels93's Avatar
How should I go about replacing my sunroof gasket? Which kind should I get and stuff. Sorry I have so many posts...a lot of stuff needs to get fixed..
ThunderONWheels93 is offline
post #2 of 10 (permalink) Old 02-01-2006, 05:56 PM
jk69cat's Avatar
ford only , and its not cheap , pn f4sz.6351884.a msrp is 209.70 , ands glued/stapled on .
mn12 less!
jk69cat is offline
post #3 of 10 (permalink) Old 02-09-2006, 02:00 PM
bad93bird's Avatar
You got to be kidding me? No place else carries the gasket? That sucks rice burners!
bad93bird is offline
post #4 of 10 (permalink) Old 02-09-2006, 02:03 PM
jk69cat's Avatar
trust me even with my dealer employee discount , i looked, its wasnt that much cheaper to me
mn12 less!
jk69cat is offline
post #5 of 10 (permalink) Old 02-09-2006, 02:07 PM
bad93bird's Avatar
Is it a pain in the arse to do?
post #6 of 10 (permalink) Old 02-09-2006, 02:11 PM
jk69cat's Avatar
ill let you know in a week, i have never put mine on my car but will soon
mn12 less!
jk69cat is offline
post #7 of 10 (permalink) Old 02-09-2006, 02:28 PM
Rolling-Thunder's Avatar
Check out the threads in this search....
http://www.sccoa.com/forums/search.php?searchid=367094
Webasto makes the sunroff, and offers the seals for a much lower price
Here's one post from the search results
"Webasto's aftermarket division still sells replacement rubber gaskets that fit our sunroof. 1-800-860-7866 is the number for their order desk. Tell them it is the Starlite 6 gasket #S1286-D5010A. That may be the OE number so they will cross reference it for the aftermarket rubber one. While you are at it, it is well worth it to replace the lifter arms at the same time. S1289-W-3000A and S1289-W-3001A are the two numbers for those. They were $9 and change each and fixed the rattle I had every time I hit a bump."
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #8 of 10 (permalink) Old 02-09-2006, 05:49 PM
bad93bird's Avatar
Mine doesn't rattle, yet! It doesn't work right! But it leaks like Niagra falls in the rain. It pulled apart at the gasket ends on the passenger side of the car. My whole interior gets wet when it rains. I have to put plastic over it when it rains. It sucks!http://www.sccoa.com/forums/search.php?searchid=367094 is not working.
post #9 of 10 (permalink) Old 02-09-2006, 06:09 PM
Just do search over there using the term "webasto"
post #10 of 10 (permalink) Old 02-09-2006, 10:19 PM
bad93bird's Avatar
Does webasto have a web site? I'll search for it.
