question: which will fit? - TCCoA Forums
post #1 of 6 (permalink) Old 02-04-2006, 10:24 AM Thread Starter
hi, i need to replace my entire cowl, both pieces. i want to find the stuff at the junkyard so i don't have to pay much. does anyone know what will fot on a 1990 cougar xr7? i know an 89 cowl will fit, will t-bird parts work?
thanks a bunch,
James
lazerviking is offline
post #2 of 6 (permalink) Old 02-04-2006, 10:34 AM
jk69cat's Avatar
well it depends if yourcar had the tsb for the cowel panel leak done to it , ifit did ,its like 91-93 ,
mn12 less!
jk69cat is offline
post #3 of 6 (permalink) Old 02-04-2006, 03:05 PM Thread Starter
tsb?
post #4 of 6 (permalink) Old 02-04-2006, 09:39 PM
jk69cat's Avatar
techincal service bullitin , ill see if i can dig it up wensday when i go back to work
mn12 less!
jk69cat is offline
post #5 of 6 (permalink) Old 02-05-2006, 01:10 AM Thread Starter
oh, thanks a lot could someone tell me more about the "technical service bullitin"?
thanks in advance if you do,
James
post #6 of 6 (permalink) Old 02-05-2006, 11:12 AM
jk69cat's Avatar
it basicly has you install a hat on the fresh air intake for the passenger compartment and requires a different cowel piece, let me dig i might be able to find it before i go back to work
mn12 less!
jk69cat is offline
