aftermarket foglamps - TCCoA Forums
post #1 of 8 (permalink) Old 11-13-2002, 02:09 PM Thread Starter
ZackG's Avatar
How do guys have them wired? Mine stopped working so im lookin at another wiring route. I dont like wires just being jammed into a fuse panel (came that way from previous owner). Any insight?
97 Tbird 4.6
Vortech at XY psi
4.10's, KB boost a spark.
Yummy.
ZackG is offline
post #2 of 8 (permalink) Old 11-13-2002, 02:23 PM
Firm Believer in Isolation Relays...
I have mine wired as follows:
Primary wire connected to the "post" on the fuse box
Wired to a 30 Amp slow blow fuse
Wired to the common of a 30 Amp, two outlet, N/O automotive relay
Then from the two outlets of the relay to the individual fog lamps.
To trigger the relay, I just tapped onto one of the low beam leads and ran it to the trigger post on the relay. The ground for the trigger (on the other side of the coil of the relay) is just grounded to the same hole that mounts the relay.
The only drawback is that there is no individual switch inside the car and the fog lights are always on when low beams are on.
That’s just how I wired mine and it keeps all the load off any switches.
69 F100 LWB w/460 Engine
post #3 of 8 (permalink) Old 11-13-2002, 05:38 PM
Re: aftermarket foglamps
I tapped off a wire bundle from the unused info center. Since my car didn't come with that option. I ran a seperate relay so I can control when they go on and off. I think the factory telling me when to use them is bogus.
My .02
Jim Long
Blown94SC is offline
post #4 of 8 (permalink) Old 11-15-2002, 11:45 PM
ben_cline's Avatar
I got some $40 foglamps with remote. Only 2 wires and some installation required. Look nice, no switches. www.cardomain.com/id/93cougarxr7se
ben_cline is offline
post #5 of 8 (permalink) Old 11-17-2002, 05:07 PM
Alex's Avatar
Send a message via AIM to Alex
I have mine wired directly to the battery, with the relay getting power via tapping into the autolamp module next to the headlight switch. That way my foglamp relay switch only turns on when my lights are on.
1991 Mercury Cougar LS (Dead)
1989 Ford Probe LX (Dead)
1989 Ford Taurus SHO (Sold)
1994 Ford Taurus SHO (Dead)
1994 Ford Taurus SHO (Weekend Cruiser)
1999 Honda Accord EX (Daily Driver)
Alex is offline
post #6 of 8 (permalink) Old 11-17-2002, 11:19 PM
Refrigerator Raider Hater
GreenBird's Avatar
I wired mine a tiny switch, it has a red and green LEDs inside. when they are off, the button glows red, when they are on, it glows green. I mounted it just in back of where the center console meets the dash.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #7 of 8 (permalink) Old 11-18-2002, 07:46 AM
Back when I had the fog lights on I was bored one day and wired them up to two separate switches. Indepent control of each.
Preston
SmallTownBird is offline
post #8 of 8 (permalink) Old 11-18-2002, 11:45 AM Thread Starter
ZackG's Avatar
thanks guys, i got some ideas now. 94 Daily Driven 4.6L: when you say the post on the fuse box, what exactly do you mean? The ppl who had the car before me just got a wire and jammed it into 1 of the fuse holes w/ an inline fuse goin to the interior. baaaaad idea. im just lookin for somewhere for tap off the power.
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
